Help! 01 S60 2.4: Weird noise in lower gears.
Hello, guys!
I have a problem with my 01 S60 2.4, and I hope some of you could help me find a solution for it. The car now has about 98,500 miles and everything works perfectly, except for one. The car makes a growling and rattling noise at start-up when it has been sit for a while. If the car is warm, the noise is reduced. On the road, the noise comes out at around 1.8k rpm in lower gears. Any help will be greatly appreciated. Thanks. |
RE: Help! 01 S60 2.4: Weird noise in lower gears.
Does the noise show up if you rev it in park?
Yes, it does show up when I rev it in park.
The noise is loudest (around 1.5k rpm)when I turn on the car for the first time in the morning. Btw, thanks for the quick response! |
You might have bad oil pan o-rings causing low oil pressure making the lifters noisey.
If that is the cause, when I get an oil change at the dealership and ask them to replace the bad oil pan o-rings, the noise will go away, correct?
What are the lifters? Thanks. |
If that is the problem and they replace the o-rings yes the noise will go away if it is indeed the lifters.
The lifters go between the Camshaft and Valves on the head. |
Car is going into the dealership for an oil change tomorrow morning.
Do they usually replace the o-rings during each oil change, or will I have to ask them to do the job? |
You would have to ask.
The Dealer will want to charge about $400.00 I believe just to replace the oil pan o-rings. |
