Help! 01 S60 2.4: Weird noise in lower gears.
Old Feb 23, 2008 | 06:15 PM
booyaolian's Avatar
Default Help! 01 S60 2.4: Weird noise in lower gears.
Hello, guys!
I have a problem with my 01 S60 2.4, and I hope some of you could help me find a solution for it.
The car now has about 98,500 miles and everything works perfectly, except for one.
The car makes a growling and rattling noise at start-up when it has been sit for a while.
If the car is warm, the noise is reduced.
On the road, the noise comes out at around 1.8k rpm in lower gears.
Any help will be greatly appreciated.
Thanks.
Old Feb 23, 2008 | 06:16 PM
Default RE: Help! 01 S60 2.4: Weird noise in lower gears.
Does the noise show up if you rev it in park?
Old Feb 23, 2008 | 06:22 PM
booyaolian's Avatar
Yes, it does show up when I rev it in park.
The noise is loudest (around 1.5k rpm)when I turn on the car for the first time in the morning.
Btw, thanks for the quick response!
Old Feb 23, 2008 | 06:30 PM
You might have bad oil pan o-rings causing low oil pressure making the lifters noisey.
Old Feb 23, 2008 | 06:35 PM
booyaolian's Avatar
If that is the cause, when I get an oil change at the dealership and ask them to replace the bad oil pan o-rings, the noise will go away, correct?
What are the lifters?
Thanks.
Old Feb 23, 2008 | 07:31 PM
If that is the problem and they replace the o-rings yes the noise will go away if it is indeed the lifters.
The lifters go between the Camshaft and Valves on the head.
Old Mar 21, 2008 | 03:44 PM
booyaolian's Avatar
Car is going into the dealership for an oil change tomorrow morning.
Do they usually replace the o-rings during each oil change, or will I have to ask them to do the job?
Old Mar 21, 2008 | 06:43 PM
You would have to ask.
The Dealer will want to charge about $400.00 I believe just to replace the oil pan o-rings.
david87
Sep 10, 2024 09:26 AM
swiftjustice44
Oct 25, 2012 06:32 AM
Smackfiend
Aug 12, 2009 08:28 PM
hohoho43
Sep 15, 2007 11:27 AM
Sweet T5R
Jun 4, 2007 06:28 PM
