Help - clutch pedal stuck to the floor
Hi guys, did my research but came up with no real answers. 2001 S60 T5
The clutch pedal is stuck on the floor (you can lift it with your hand).
Had to start the car in gear and bring it home in first gear. I assume it's the clutch master that is shot near the tranny.
Open the the bleeder and hear some suck and blow but not much and the brake reservoir is full.
How do you remove the stupid thing? I pulled the clip to remove the line but the rest looks like it's held on but flimsy metal brackets that I'm afraid to snap.
I don't see any fluid anywhere so maybe this is a quick fix - please advise
thanks!
thanks!
The clutch master cylinder isn't hard, but that isn't your problem. The slave cylinder is what actually releases the clutch. Book time is about 8.5 without AWD and 9.5 with AWD. I think it took me 5.5 or 6 the first time, but it would be much more difficult without a lift and trans jack.
The special tool is to compress the teeth on the clutch when installing it.
Cleaner13
08-03-2014 09:34 AM
