Help decoding a vin
Hello, I'm new here and am looking at a 2005 s60r. The description of the vehicle reads premium package but the pictures look like it has a single disc cd. Can someone decode the vin to let me know what all is on this vehicle? VIN YV1RH527552477312
Thanks |
Looks like it does not have a CD changer.
0101 GEMENSAMT VAGN GEMENSAMT VAGN 0201 Common material Common 10BM INTERIOR CODE Gobi,grey/gold, S60 R-LINE 1165 EXTERIOR CODE Black Sapphire metallic 1202 EXTERIOR PAINT,TYPE Metallic exterior paint 1301 CLEARCOAT Standard clearcoat 2B01 ADDITIONAL HEATER,FUEL Without additional heater 2C01 EL CAR HEATER Without el car heater 2D01 CUPE´ VENTILATION Without timer controlled cupé ventilation 2E01 WASTE HEAT UTILIZER Without waste heat utilizer 2F01 ACCESSORY ELECTRONIC MODUL W/O accessory electronic module 2G02 HOSE FOR HEATER Hose for cars with no heater 2H01 CALLSTART OF PARKING HEATER W/o callstart of parking heater 2I01 EXTERNAL ALARMUNIT SUPPLY W/o wxternal alarm unit supply 2J01 HANSDSFREE TELEMUTE FUNCTION W/o telemute function 3802 TWEETER FRONT DOOR Extra variant, Tweeter 4102 FMVSS-DECAL/PLATE FMVSS decal for USA 4201 EuroNCAP Decal if PASS.AIRBA Without EuroNCAP decal 4501 COMMON MATERIAL P26/P24 Common material P26/P24 4601 COMMON MATERIAL P23/P26/P24 Common material P23/P26/P24 4602 COMMON MATERIAL P23/P26/P24 Common material P23/P24/P26 4X31 MARKET CODE Market variant, not for part steering 5101 ADMINISTRATIVE FOR S-CAR Adm variant for standard car 5502 MMS PREPARATION W/o MMS-preparation,extra variant 6615 FRONT SHOCKABSORBERS Shock absorbers typ 7, R-line 6806 FRONT STABILISER Front stabiliser bar D=23.5 mm,H 6916 REAR STABILISER Rear stabiliser bar D=20.0 mm R-line 6A08 EXTRAVARIANT WHEELUNITS FRONT Extravariant 6B08 EXTRAVARIANT WHEELUNITS REAR Extravariant 7101 RADIO Extra variant 7406 VEHICLE TYPE / GEAR BOX TYPE Extra variant 7602 SWITCH BLOCK PANEL, 7 IN ROW Panel for max 7 switches Extra variant 7740 FRONT SPRINGS-(weight) Extra variant 7817 REAR SPRINGS-(weight) Extra variant 7902 Total weight check Carweight is OK 8024 CABLEHARNESS COUPE Extra variant 8137 CABLEHARNESS ENGINE COMPARTMENExtra variant 8308 CABLEHARNESS REAR Extra variant 8403 CABLEHARNESS ROOF Extra variant 8502 FRONT SEAT,LEFT Extra variant 8603 FRONT SEAT,RIGHT Extra variant 8701 FRONT SEAT, LEFT HAND SIDE Extra variant 8801 FRONT SEAT, RIGHT HAND SIDE Extra variant 8905 EXTRA VARIANT STEERING WHEEL Extra variant 8B02 GEARBOX/DRIVELINE 5-speed automatic, 2WD and 4WD 8D08 REAR WIEW MIRROR PACKAGE Mirrorpackage 8 8G02 ADM Family for airbag assemblyAirbag module with snapin 8H04 Gearbox extra variants Automatic 5speed 8I01 OPTIONAL CABLES, S-CARS Without optional cables 8W01 EXTERIOR PARTS Standard articles 9201 SLIDE RAILS, FRONT SEAT Extra variant, long slide rail 9401 PANEL LH SIDE REAR V70 Extravariant 9B00 DMU,administrative family Not applicable variant, no parts allowed 9I00 ADMINISTRATIVE FAMILY Not applicable variant, no parts allowed 9J00 ADMINISTRATIVE FAMILY Not applicable variant, no parts allowed 9K00 ADMINISTRATIVE FAMILY Not applicable variant, no parts allowed 9M00 ADM.FAMILY FOR MEASURED CARS Not applicable variant, no parts allowed 9N00 ADMINISTRATIVE FAMILY Not applicable variant, no parts allowed 9O01 ADM FOR RESTRICTION Adm for restriction Police cars 9P01 PARTS FOR SPECIAL VEHICLES Parts excluded for Special Vehicle Executives 9Q01 ADM FOR S-CAR RESTRICTION Adm variant for restrictions 9R01 ADMINISTRATIVE FAMILY Not applicable, no parts allowed 9S01 ADM FOR RSE-RESTRICTION Adm variant 9T00 ADM.FAMILY FOR TESTCARS Not applicable variant, no parts allowed 9U00 Adm. for police cars Not applicable variant, no parts allowed 9V01 FAMILY FOR COLOUR CHANGE Not applicable AC10 VEHICLE MAIN TYPE P24 wheel base 2715 mm AE05 VEHICLE SUB TYPE S60 Body type standard P24 AF03 DOORS 4 door AG02 POWER TRAIN AWD 4-wheel drive AJ02 POWER TRAIN CAR CONFIG. VARIANT AP15 SALES VERSIONS - FOR LISTS Sales version 93 AS01 STANDARD/SPECIAL VEHICLE Standard car unique material C101 STEERING POSITION Left hand drive C302 MARKET USA(fed-cal)/Canada C402 MAIN MARKET DECALS/SIGNS Decals outside Nordic CB03 ENGINE DYNAMICS/STC 5-cyl high press turbo,petrol CD01 BIFUEL Not Bifuel CE07 GENERAL ENGINE VARIANTS 2,5 l turbo engines CF11 ENGINE 5cyl/2.5l/4V/HT 300/400, 220 kW 2521CC 2,521 L CG01 FUEL Petrol CH02 CYLINDERS ENGINE,(gasoline) 5-cylinder gasoline engine CJ02 CYL. TURBO ENGINES(gasoline) 5 cylinders turbo gasoline engines CK01 CYL/VALVES ENGINE - PETROL 5 cylinder/4-valve engine CL02 TURBO,(gasoline) With turbo CN01 RETURN LESS FUEL SYSTEM Return Less Fuel System CO02 EXHAUST SYSTEM Exhaust system, R-line CP02 STARTER MOTOR Startermotor 1,4+ KW, 5CYL, M56/M66/ AW gearbox,cold market CQ03 BATTERY 600 Cold cranking Amp CR02 ALTERNATOR Alternator 143A EXEC CS02 BUSHING, LINK ARM Solid bushings, link arms CT02 ENGINE PAD, FRONT AND REAR Engine pad petrol, R-line CU02 OIL LEVEL SENSOR Oil Level Sensor CX02 ENGINE COOLING FAN Engine cooling fan, high performance (Brush Less Direct Current) DB16 GEAR BOX 5-speed Automatic AWD DC01 NEUTRAL CONTROL AUTO.GEAR Without NEUTRAL CONTROL func DD03 PEDAL ARRANGEMENT Pedal arrangements, standard DF02 GEAR BOX TYPE Automatic gearbox DG02 SHIFTLOCK With shiftlock DH02 GEARTRONIC AUTO GEARBOX Geartronic DI11 GEAR LEVER TYPE/KNOB Gearlever knob leather, R-line DK03 VISCO DIFFERENTIAL Electrical Controlled Limited Coupling AWD (HALDEX) DL01 TRANSMISSION OIL COOLER, AUTO Without Transmission Oil Cooler DN01 EXTRA AIR TO OIL COOLER,TRANSMWithout extra air oilcooler DO02 RADIATOR,TYPE Radiator, high performance DP01 START BLOCKING MAN GEARBOX Without start blocking DQ01 EXTRA WATER COOLER,FUEL Without Extra water cooler E101 OWS calibration ID No calibration ID EB01 AIR CONDITION, REAR Without rear air condition EC02 AIRCONDITION With aircondition ED05 CLIMATE UNIT Electronic climat control EE02 GRADUATION CLIMATE CTRL-IF ECCFahrenheit gradiation EI01 COOLING BOX Without Cooling box EJ01 CUT OFF SWITCH PASS. AIRBAG Without passenger airbag cut-off switch EK01 B-PILLARVENTILATION B-pillar ventilation EL01 SAFETY BELT ALR (automatic locking retractor) EM02 AIRBAG Airbag EN02 AIRBAG TYPE Airbag driver/pass side EO04 AIRBAG Airbag driver/pass side with knee restraint EP02 AIRBAG,PASSENGER SIDE Airbag, pass side, no cutoffswitch EQ02 KNEE RESTRAINT Knee restraint ES05 OCCUPANT WEIGHT SENSOR Without OWS ET03 SIPSBAG, FRONT SEAT Sipsbag, USA model EV02 ROOF HATCH Roof hatch EX01 SEAT BELT MINDER, PASSENGER Without seat belt minder F101 COLOUR PACKAGE,INTERIOR Colour package interior F201 COLOUR PACKAGE,EXTERIOR Colour package exterior FA01 COLOUR MATCHING INTERIOR Colour matching interior FA02 COLOUR MATCHING INTERIOR Colour matching interior FA03 COLOUR MATCHING INTERIOR Colour matching interior FA04 COLOUR MATCHING INTERIOR Colour coordination interior FA07 COLOUR MATCHING INTERIOR Colour coordination interior FA08 COLOUR MATCHING INTERIOR Colour coordination interior FA10 COLOUR MATCHING INTERIOR Colour coordination interior FA15 COLOUR MATCHING INTERIOR Colour matching carpets FA17 COLOUR MATCHING INTERIOR Colour matching doors FA26 COLOUR MATCHING INTERIOR Colour matching coulisse FA45 COLOUR MATCHING INTERIOR Colormatching, frame keypad FA51 COLOUR MATCHING INTERIOR Colour matching seat belts 2 FA54 COLOUR MATCHING INTERIOR Colour matching sewing thread FA57 COLOUR MATCHING INTERIOR Colour matching interior FA66 COLOUR MATCHING INTERIOR Colour matching doors FA68 COLOUR MATCHING INTERIOR Colour coordination sewing thread FA69 COLOUR MATCHING INTERIOR Colour coordination label FA70 COLOUR MATCHING INTERIOR Colour matching SIPS trhead FA72 COLOUR MATCHING INTERIOR Colour matching thread FA74 COLOUR MATCHING INTERIOR Colour matching thread FA75 COLOUR MATCHING INTERIOR Colour matching thread FA76 COLOUR MATCHING INTERIOR Colour matching thread FA80 COLOUR MATCHING INTERIOR Colour matching inner doorhandle FB01 COLOUR MATCHING EXTERIOR Colour matching exterior FB02 COLOUR MATCHING EXTERIOR Colour matching exterior FKBF COLORS,INT/EXT Black metallic FKBT COLORS,INT/EXT Grey/Gold G101 PROTECTION PLATE CAT Without Prot.plate catalyst G502 FILLER PIPE Small filler pipe G605 FUELTANK,CAPACITY Capacity 68 litre, R-LINE G801 FILLING NOZZLE BIFUEL Without Filling nozzle G902 FUEL LEAKAGE DETECTION Fuel leakage detection GA05 EMISSION, EVAPORATION SYSTEM Evaporator system ULEV Prim GB01 DIAGNOS SYSTEM OBD 2 GKAM EMISSION CODE Emission level Lev2 VIN pos8=7 GM02 LEAD RESISTANT LAMBDA PROB Without lead resistant Lambda sond GX00 LOAD MODULE ECM Not applicable variant, no parts allowed IA01 WASTE BIN IN TUNNELCONSOL Without Waste bin in tunnel- console IB02 WASTE BIN, FIXPOINT Without Waste bin JA02 MAIN LIGHTS, TYPE USA design JB10 HEAD LIGHT, SYMMETRY White right assymetrical, 1xH7 + 1xGDL bulb, bezel R-line JC01 AUTOMATIC DIPPED HEADLIGHT Always dipped headlight exceptin position P. Adjustable JF03 HEAD LAMP ADJUSTER Automatical headlight adjustment JG02 HEAD LIGHT CLEANERS Wipers JJ04 THEFT PROTECTION BRACKET P28 Without protection bracket side door P28 JK00 REAR FOG LIGHT, POSITION Not applicable variant, no parts allowed JL02 LIGHT SOURCE, STOPLIGHT REAR Light bulb JS01 REAR FOGLIGHT,TOWFUNCTION Foglights running even when trailer is connected JT03 FOGLIGHTS,FRONT IN SPOILER Foglights in front spoiler (head light restricted) K001 MOBILE OFFICE Without mobile office K161 CASSETTE/CD RADIO Casette radio with CD-play K205 LOUDSPEAKER PACKAGE Loud speakers side doors,rear shelf K401 MD-PLAYER P28 Without MiniDisc-player K501 AMPLIFIER Without Amplifier K601 CD/MD-CHANGER Without CD cables K900 TELEPHONE SYSTEM Not applicable variant KA01 SPEED LIMITATION Speed limitation, 250 Km/h KB05 INSTRUMENT CLUSTER MPH gradation, USA R-line KC02 SPEED WARNING Without Speed warning device KD01 HEADPHONE SOCKETS,REAR Without rear headset sockets KE03 TRIP COMPUTER Trip computer KG02 CRUISE CONTROL Cruise control KH01 REAR SEAT ENTERTAINMENT Without RSE KI03 TV RECEIVING SET Without TV receiving set KJ02 BELT REMINDER USA type, incl. key warning KL01 BRAKE CONTROL Without Brake control KN01 LOUDSPEAKER,D-POST WITHOUT LOUDSPEAKER D-POST KO02 LOUDSPEAKER,FRONT DOOR Loudspeakers front side doors KP02 LOUDSPEAKER,SIDE DOOR REAR Loudspeakers rear side doors KQ01 MICROPHONE Without microphone KR02 LOUDSPEAKER,HATSHELF Loudspeaker hatshelf KT03 PANEL RADIO PREPARATION Radiopreparation in Centrestack VOLVOradio type HU-XXX KU01 CENTRE LOUDSPEAKER,DASHBOARD Without Centre loudspeaker, Dash KV04 BASS LOUDSPEAKER LUGG.COMP Without subwoofers lugg.comp. KW11 CUPHOLDER DASHBOARD Without Cupholder in Dashboard KX01 RTI/TV DISPLAY,DASH Without RTI/TV display, Dash KY02 DIVERSITY ANTENNA, BUMPERS Diversity antenna KZ01 TELEPHONE Without telephone L002 LOGO, remote control R-line LOGO, remote control L102 ALARM / REMOTECONTROLES Alarm, 10 alarm cycles L203 LOCK TYPE,CENTRAL LOCKING 2-Step opening, Central lock L302 ALARM ACT VIA DOORLOCK Alarm activive with door key L401 CHILD LOCK Without Electrical child lock L501 PASSIVE ALARM ACTIVATION W/o automatic alarm activate L601 RETRIGG ENABLING - IF ALARM Without Retrigg functionality L802 LEVELSENSOR-IF ALARM Without level sensor L901 EXTRA EQUIPMENT-IF VGLA Without unique material LA02 REAR VIEW MIRROR,HEATING Electrically heated mirrors LD04 REAR VIEW MIRROR GLAS,DRIVER LH side mirror,flat LE08 REAR VIEW MIRROR GLAS,PASS SIDRH side mirror,radius 1400 english text LK02 LIGHT IN OUTER MIRRORS Light in outer mirrors LN02 TRUNK ENTRAPMENT RELEASE Trunk entrapment release LP01 CIG. LIGHTER/ASHTRAYS Without Cigarette lighter LQ02 PRIVATE LOCK LUGGAGE COMP. Private lock trunk comp. with disable buttom LR01 DARKENED REAR WINDOWS Without Dark glass rear LT01 GLASSBRAKE WIRE/SENSOR Without Glassbrake wire in rear glass LU01 AUTOMATIC LOCKING Without automatic doorlocking LV01 MASSMOVEM. SENSOR-IF ALARM Without massmovement sensor LW01 BLIND SPOT INFORMATION SYSTEM Without Blind spot Information System LX09 GLASS,REAR VIEW MIRRORS LH side mirror: Flat .RH side mirror: R1400 English text LY15 FREQUENCY REMOTE-IF REMOTE 315.00 Mhz, High effect with panic function LZ09 SECURITY PACKAGE Security pagage 9 (lock & alarm) M102 Memory With memory M201 Retractable sideview mirrors Without retractable mirrors M304 Rear view mirrors Memory mirror w/o retractable M404 Rear view mirrors Memory mirror w/o retractable M902 DOOR HANDLE, FRONT Door handle, R-line MB03 TELEPHONE HANDSFREE Without handsfree phone MC04 COUPEFILTER Air Quality System MI01 ACKNOWL. SIGNAL LOCK/ALARM LOCK ACKNOWLEDGE (NO UNLOCK) MN02 FREQUENCY BAND & STEP,RADI Frequency band and step for USA MO11 LANGUAGE US ENGLISH for instrument and radio MP02 WALLET CUSTOMER INFO Leather wallet MR02 AUTO UP WINDOW LIFTS Auto up, front doors MS05 INSTRUCTIONS Owners manual American/English, no warranty booklet MT01 INSTRUMENT CLUSTER CALIBR. Parameter file for USA MU12 SERVICE INTERVAL Serviceinterval 2 N001 SIDE POCKET, TRUNK Without side pocket in trunk N101 LUGGAGE NET, STEEL Without Steelnet N201 LUGGAGE NET, TEXTILE Without Luggage net N401 LOAD HOLDING TRUNK Without Load holding N505 CHILD SEAT/CUPH. ARMREST REAR Armrest with cupholder N603 CHILD S-BELT ATTCHM REAR Prepared for child belt attachm,2 plugs N702 CHILD SEAT ATTCHM Child seat attchm N801 ATTCHM CHILD SEAT FRONT Without child seat attchm N901 CHILD SEATS REAR,OUTER Without outer child seat NA02 DOOR PANEL,FRONT Front door panel, sport NC24 TRIM PANEL Brushed aluminium ND01 EXTRA SEAT Without Extra seat NE00 ARMREST,DOORPANEL-IF LEATHER Not applicable variant, no parts allowed NF03 HANDBRAKE LEVER Handbrake lever, R-line NG49 UPHOLSTERY MATERIAL Softleather NH02 PROTECTION VISOR, COMBI INSTR Protection visor, combi instrument, R-line NI03 DRIVER SEAT Power driver seat with memory NJ03 PASSENGER SEAT Power passenger seat without memory NL01 SEAT HEAT CALIBRATION Without Seat heat NM01 HEATED SEAT Without heated seat NO02 HEADREST REAR,FOLDING Electrically foldable rear headrests NP01 SPLIT REAR SEAT 40-60 split NQ04 CENTRE CONSOLE FRONT R-line tunnel console NS01 LOCK REAR FLOORLID Without lockable rear floor lid NV02 CUP HOLDER,TUNNEL CONSOL 2 cup holders without ashtray NY04 PROTECTION CARPET SET,COUPE Carpet set, R-line NZ03 FLOOR CARPETS Floor carpets, R-line PA02 SUNVISOR, UPHOLSTERY Sunvisor, textil PB03 MAKEUP LAMP SUNVISOR Illuminated mirror driver/pass PE01 12 VOLT OUTLET LUGGAGE Without 12V outlet in luggage PF00 HANDLE TAILGATE 5-DOOR Not applicable variant, no parts allowed PI03 FIRST AID KIT Without first aid kit PK02 LOADCOVER,5-DOOR Without rear shelf 5-door PL01 SUN BLIND,REAR WINDOW Without Sun blind (not executive) PM01 SUN BLIND,REAR SIDE DOOR WIN. Without sun blind rear sidedoor PN02 INSIDE REAR VIEW MIRROR TYPE Automatic dimning of inside rear view mirror PP02 HOME LINK With Home Link R001 SELF SUPPORTING TYRE W/O self supporting tyre R148 RIM A 17' 8Jx17x46 R-CAR R531 TYRE DIMENSION 235/45R17 R609 SPARE WHEEL Spare T115/85R18 R701 LOCKABLE WHEELBOLTS-IF ALU RIMWithout lockable wheelbolts R817 TYREBRAND Pirelli PZERO R905 TYRE CIRCUMFERENCE Rolling circumference 1960mm RA16 CHASSIE TYPE Chassi LOW SPORT, adjustable and active, Four-C R RB03 ACTIVE SUSPENSION Continious Controlled Chassi Concept, R-line RC03 BRAKE ASSISTANCE Electrical Brake assistance RE03 BRAKES,TYPE 17,5 inch brakes, FNR RF05 ANTI LOCK BRAKE SYSTEM ABS with Dynamic stability traction controle RG01 TYRE PRESSURE MONITORING S Without Tyre Pressure Monitoring System RH01 ROADFRICTION DETECTION Without Road friction detection RI01 LEVELING SYSTEM Without Leveling system RJ02 EL.VACUMPUMP, REAR BOOSTER Electrical vacumpump RK04 STEERING WHEEL, MODEL Steering wheel 3 spoke, R-LINE RL01 WHEEL MATERIAL Aluminium Wheel RM03 WHEEL, INCH 17' Wheel RQ00 JACK XC90 Not Applicable RQ RU02 STEERING WHEEL Steering wheel, leather RV03 STEERINGWHEEL MODULE Satelite for Audio RW01 ROLL STABILITY CONTROL Without Roll Stability Control RX05 STEERING GEAR Steering gear, R-LINE (ZF) RY01 VIBR. DAMPER STEERING WHEEL With vibr. damper SC01 TABLE IN REAR SEAT Without table in rear seat SF02 COMMUNIKATION TAXI Without el-cable Taxi. T001 EMBLEM REAR LH Belt tongue long T102 EXTRA EMBLEM REAR RH R-line emblem, rear T227 ENGINE EMBLEM REAR RH Emblem 'AWD' T301 DECAL TRIMLEVEL Without trim decal T401 WATER REPELLANT SIDE WINDOWS Without water repellent side windows T601 SIDEWINDOWS Hardened side windows T701 RAIN SENSOR Without rain sensor T802 WINDSCREEN Tinted windshield with band TE03 SILL MOULDINGS Sill moulding and lower doormoulding in colour TG03 SPOILER REAR With rear spoiler TJ02 BUMPERS COLOUR MATCHED Front for R-line TK02 NUMBER PLATE HOLDER Number plate holder type USA TN06 WAIST MOULDING Waist moulding in car colour. TP02 ROOFRAILS Without roofrails TS02 WARNING TRIANGLE Without warning triangle TU01 AIR SEALING Air sealing for R-line TV02 AIRGUIDE SPOILER Bumper without airguide TX01 MUDFLAPS,REAR Without mudflaps TY01 MUDFLAPS,FRONT Without front mudflaps TZ01 AIR FILTER Airfilter R-line/24HT UB02 TRANSPORT STRAPS With transport eye UC01 DIRT DEFLECTOR Without Dirt deflector UD02 BATTERY MAIN SWITCH With Battery main switch UE02 BATTERY MINUS CABLE Battery minus cable, new long VA01 CONTROL UNIT RTI Without control unit, RTI VB01 CD/DVD-ROM DISC - IF RTI Without CD-ROM VC02 REM, rear electronic module High spec REM VD01 RTI SYSTEM (OM RTI) ALT. PREP.Without RTI preparation VE01 NIGHT VISION Without Night Vision VF02 AEM PREPARATION AEM preparation (Acessory Electronic Module) VG01 VOICE CONTROL Without voice control VH01 INTERCOM Without intercom VI01 TMC Traffic Message Chann Without TMC VJ01 GPS Global Positioning Sys Without GPS VK01 INFOTAINMENT SYSTEM Without infotainment system VM01 INFOTAINMENT THEFT PROTECTION Without InfotainmentTheft protection VP04 PARK ASSISTANCE With parking assistance rear (REM) VR02 SATELLITE PREP. Satillite prep. XA00 MARKET DECALS/SIGNS Decals for USA XA02 MARKET DECALS/SIGNS Decals out Japan XA11 MARKET DECALS/SIGNS Decals out Australia XA25 MARKET DECALS/SIGNS Decals outside France XA34 MARKET DECALS/SIGNS Decals for California XA40 MARKET DECALS/SIGNS Decals outside Canada XA47 MARKET DECALS/SIGNS Decals Outside China XB15 PACKAGES FOR PLATES AND DECALSDecals for MC 31 XD01 USER PACKAGES For VEC XE02 USER EXCEPTIONS Only for VCG XE03 USER EXCEPTIONS Not for VCT XE06 USER EXCEPTIONS Not for Thailand XE08 USER EXCEPTIONS Not for Malaysia XE11 USER EXCEPTIONS Not for Thai, Mal, Indo, Daqing XE19 USER EXCEPTIONS Not for Indonesia XE21 USER EXCEPTIONS Only for ECG XI02 DECAL FOR TYRE PRESSURE Tyre pressure decal type 2 Y807 VIN pos 4 or 7 VIN-code position 4 Y915 VIN pos 5 eller 8 VIN-code position 5 YA03 Vehicle inspection number YV1 YB05 YEAR DESIGNATION LETTER Year des 5 = model year 2005 YC14 MAX FRONT AXLE WEIGHT 2420 lb, V70 XC 1100 kg (USA) YD27 MAX REAR AXLE WEIGHT 2310 lb YE53 GROSS WEIGHT 4540 lb YF99 TRAIN WEIGHT Without weight YG24 MAXIMUM LOAD 350 kg or 770 lbs YH04 TYRE PRESSURE HEAVY LOAD F:270kPa/39psi, R:270kPa/39psi YI06 TYRE PRESSURE LIGHT LOAD F:240kPa/35psi, R:240kPa/35psi YJ04 TYRE PRESSURE SPARE WHEEL 420 kPa/61 psi YL00 SUPPLEMENTSINFO FOR WVTA-NR Not applicable variant, no parts allowed YM17 TYRE PRESSURE HEAVY LOAD, TPM Tyre pressure warning 41 PSI YP00 WVTA-NUMBER Not applicable variant, no parts allowed |
Where did you find all of that information? I am having the same issue with my VIN.
