Help decoding a vin
Old May 1, 2014 | 11:30 PM
Homerfeltheim's Avatar
Default Help decoding a vin
Hello, I'm new here and am looking at a 2005 s60r. The description of the vehicle reads premium package but the pictures look like it has a single disc cd. Can someone decode the vin to let me know what all is on this vehicle? VIN YV1RH527552477312
Thanks
Old May 2, 2014 | 06:15 PM
difflock54's Avatar
Try this link.
Volvo S60 VIN Plate Identification
Old May 3, 2014 | 09:54 AM
ES6T's Avatar
Looks like it does not have a CD changer.
0101 GEMENSAMT VAGN GEMENSAMT VAGN
0201 Common material Common
10BM INTERIOR CODE Gobi,grey/gold, S60 R-LINE
1165 EXTERIOR CODE Black Sapphire metallic
1202 EXTERIOR PAINT,TYPE Metallic exterior paint
1301 CLEARCOAT Standard clearcoat
2B01 ADDITIONAL HEATER,FUEL Without additional heater
2C01 EL CAR HEATER Without el car heater
2D01 CUPE´ VENTILATION Without timer controlled cupé ventilation
2E01 WASTE HEAT UTILIZER Without waste heat utilizer
2F01 ACCESSORY ELECTRONIC MODUL W/O accessory electronic module
2G02 HOSE FOR HEATER Hose for cars with no heater
2H01 CALLSTART OF PARKING HEATER W/o callstart of parking heater
2I01 EXTERNAL ALARMUNIT SUPPLY W/o wxternal alarm unit supply
2J01 HANSDSFREE TELEMUTE FUNCTION W/o telemute function
3802 TWEETER FRONT DOOR Extra variant, Tweeter
4102 FMVSS-DECAL/PLATE FMVSS decal for USA
4201 EuroNCAP Decal if PASS.AIRBA Without EuroNCAP decal
4501 COMMON MATERIAL P26/P24 Common material P26/P24
4601 COMMON MATERIAL P23/P26/P24 Common material P23/P26/P24
4602 COMMON MATERIAL P23/P26/P24 Common material P23/P24/P26
4X31 MARKET CODE Market variant, not for part steering
5101 ADMINISTRATIVE FOR S-CAR Adm variant for standard car
5502 MMS PREPARATION W/o MMS-preparation,extra variant
6615 FRONT SHOCKABSORBERS Shock absorbers typ 7, R-line
6806 FRONT STABILISER Front stabiliser bar D=23.5 mm,H
6916 REAR STABILISER Rear stabiliser bar D=20.0 mm R-line
6A08 EXTRAVARIANT WHEELUNITS FRONT Extravariant
6B08 EXTRAVARIANT WHEELUNITS REAR Extravariant
7101 RADIO Extra variant
7406 VEHICLE TYPE / GEAR BOX TYPE Extra variant
7602 SWITCH BLOCK PANEL, 7 IN ROW Panel for max 7 switches Extra variant
7740 FRONT SPRINGS-(weight) Extra variant
7817 REAR SPRINGS-(weight) Extra variant
7902 Total weight check Carweight is OK
8024 CABLEHARNESS COUPE Extra variant
8137 CABLEHARNESS ENGINE COMPARTMENExtra variant
8308 CABLEHARNESS REAR Extra variant
8403 CABLEHARNESS ROOF Extra variant
8502 FRONT SEAT,LEFT Extra variant
8603 FRONT SEAT,RIGHT Extra variant
8701 FRONT SEAT, LEFT HAND SIDE Extra variant
8801 FRONT SEAT, RIGHT HAND SIDE Extra variant
8905 EXTRA VARIANT STEERING WHEEL Extra variant
8B02 GEARBOX/DRIVELINE 5-speed automatic, 2WD and 4WD
8D08 REAR WIEW MIRROR PACKAGE Mirrorpackage 8
8G02 ADM Family for airbag assemblyAirbag module with snapin
8H04 Gearbox extra variants Automatic 5speed
8I01 OPTIONAL CABLES, S-CARS Without optional cables
8W01 EXTERIOR PARTS Standard articles
9201 SLIDE RAILS, FRONT SEAT Extra variant, long slide rail
9401 PANEL LH SIDE REAR V70 Extravariant
9B00 DMU,administrative family Not applicable variant, no parts allowed
9I00 ADMINISTRATIVE FAMILY Not applicable variant, no parts allowed
9J00 ADMINISTRATIVE FAMILY Not applicable variant, no parts allowed
9K00 ADMINISTRATIVE FAMILY Not applicable variant, no parts allowed
9M00 ADM.FAMILY FOR MEASURED CARS Not applicable variant, no parts allowed
9N00 ADMINISTRATIVE FAMILY Not applicable variant, no parts allowed
9O01 ADM FOR RESTRICTION Adm for restriction Police cars
9P01 PARTS FOR SPECIAL VEHICLES Parts excluded for Special Vehicle Executives
9Q01 ADM FOR S-CAR RESTRICTION Adm variant for restrictions
9R01 ADMINISTRATIVE FAMILY Not applicable, no parts allowed
9S01 ADM FOR RSE-RESTRICTION Adm variant
9T00 ADM.FAMILY FOR TESTCARS Not applicable variant, no parts allowed
9U00 Adm. for police cars Not applicable variant, no parts allowed
9V01 FAMILY FOR COLOUR CHANGE Not applicable
AC10 VEHICLE MAIN TYPE P24 wheel base 2715 mm
AE05 VEHICLE SUB TYPE S60 Body type standard P24
AF03 DOORS 4 door
AG02 POWER TRAIN AWD 4-wheel drive
AJ02 POWER TRAIN CAR CONFIG. VARIANT
AP15 SALES VERSIONS - FOR LISTS Sales version 93
AS01 STANDARD/SPECIAL VEHICLE Standard car unique material
C101 STEERING POSITION Left hand drive
C302 MARKET USA(fed-cal)/Canada
C402 MAIN MARKET DECALS/SIGNS Decals outside Nordic
CB03 ENGINE DYNAMICS/STC 5-cyl high press turbo,petrol
CD01 BIFUEL Not Bifuel
CE07 GENERAL ENGINE VARIANTS 2,5 l turbo engines
CF11 ENGINE 5cyl/2.5l/4V/HT 300/400, 220 kW 2521CC 2,521 L
CG01 FUEL Petrol
CH02 CYLINDERS ENGINE,(gasoline) 5-cylinder gasoline engine
CJ02 CYL. TURBO ENGINES(gasoline) 5 cylinders turbo gasoline engines
CK01 CYL/VALVES ENGINE - PETROL 5 cylinder/4-valve engine
CL02 TURBO,(gasoline) With turbo
CN01 RETURN LESS FUEL SYSTEM Return Less Fuel System
CO02 EXHAUST SYSTEM Exhaust system, R-line
CP02 STARTER MOTOR Startermotor 1,4+ KW, 5CYL, M56/M66/ AW gearbox,cold market
CQ03 BATTERY 600 Cold cranking Amp
CR02 ALTERNATOR Alternator 143A EXEC
CS02 BUSHING, LINK ARM Solid bushings, link arms
CT02 ENGINE PAD, FRONT AND REAR Engine pad petrol, R-line
CU02 OIL LEVEL SENSOR Oil Level Sensor
CX02 ENGINE COOLING FAN Engine cooling fan, high performance (Brush Less Direct Current)
DB16 GEAR BOX 5-speed Automatic AWD
DC01 NEUTRAL CONTROL AUTO.GEAR Without NEUTRAL CONTROL func
DD03 PEDAL ARRANGEMENT Pedal arrangements, standard
DF02 GEAR BOX TYPE Automatic gearbox
DG02 SHIFTLOCK With shiftlock
DH02 GEARTRONIC AUTO GEARBOX Geartronic
DI11 GEAR LEVER TYPE/**** Gearlever **** leather, R-line
DK03 VISCO DIFFERENTIAL Electrical Controlled Limited Coupling AWD (HALDEX)
DL01 TRANSMISSION OIL COOLER, AUTO Without Transmission Oil Cooler
DN01 EXTRA AIR TO OIL COOLER,TRANSMWithout extra air oilcooler
DO02 RADIATOR,TYPE Radiator, high performance
DP01 START BLOCKING MAN GEARBOX Without start blocking
DQ01 EXTRA WATER COOLER,FUEL Without Extra water cooler
E101 OWS calibration ID No calibration ID
EB01 AIR CONDITION, REAR Without rear air condition
EC02 AIRCONDITION With aircondition
ED05 CLIMATE UNIT Electronic climat control
EE02 GRADUATION CLIMATE CTRL-IF ECCFahrenheit gradiation
EI01 COOLING BOX Without Cooling box
EJ01 CUT OFF SWITCH PASS. AIRBAG Without passenger airbag cut-off switch
EK01 B-PILLARVENTILATION B-pillar ventilation
EL01 SAFETY BELT ALR (automatic locking retractor)
EM02 AIRBAG Airbag
EN02 AIRBAG TYPE Airbag driver/pass side
EO04 AIRBAG Airbag driver/pass side with knee restraint
EP02 AIRBAG,PASSENGER SIDE Airbag, pass side, no cutoffswitch
EQ02 KNEE RESTRAINT Knee restraint
ES05 OCCUPANT WEIGHT SENSOR Without OWS
ET03 SIPSBAG, FRONT SEAT Sipsbag, USA model
EV02 ROOF HATCH Roof hatch
EX01 SEAT BELT MINDER, PASSENGER Without seat belt minder
F101 COLOUR PACKAGE,INTERIOR Colour package interior
F201 COLOUR PACKAGE,EXTERIOR Colour package exterior
FA01 COLOUR MATCHING INTERIOR Colour matching interior
FA02 COLOUR MATCHING INTERIOR Colour matching interior
FA03 COLOUR MATCHING INTERIOR Colour matching interior
FA04 COLOUR MATCHING INTERIOR Colour coordination interior
FA07 COLOUR MATCHING INTERIOR Colour coordination interior
FA08 COLOUR MATCHING INTERIOR Colour coordination interior
FA10 COLOUR MATCHING INTERIOR Colour coordination interior
FA15 COLOUR MATCHING INTERIOR Colour matching carpets
FA17 COLOUR MATCHING INTERIOR Colour matching doors
FA26 COLOUR MATCHING INTERIOR Colour matching coulisse
FA45 COLOUR MATCHING INTERIOR Colormatching, frame keypad
FA51 COLOUR MATCHING INTERIOR Colour matching seat belts 2
FA54 COLOUR MATCHING INTERIOR Colour matching sewing thread
FA57 COLOUR MATCHING INTERIOR Colour matching interior
FA66 COLOUR MATCHING INTERIOR Colour matching doors
FA68 COLOUR MATCHING INTERIOR Colour coordination sewing thread
FA69 COLOUR MATCHING INTERIOR Colour coordination label
FA70 COLOUR MATCHING INTERIOR Colour matching SIPS trhead
FA72 COLOUR MATCHING INTERIOR Colour matching thread
FA74 COLOUR MATCHING INTERIOR Colour matching thread
FA75 COLOUR MATCHING INTERIOR Colour matching thread
FA76 COLOUR MATCHING INTERIOR Colour matching thread
FA80 COLOUR MATCHING INTERIOR Colour matching inner doorhandle
FB01 COLOUR MATCHING EXTERIOR Colour matching exterior
FB02 COLOUR MATCHING EXTERIOR Colour matching exterior
FKBF COLORS,INT/EXT Black metallic
FKBT COLORS,INT/EXT Grey/Gold
G101 PROTECTION PLATE CAT Without Prot.plate catalyst
G502 FILLER PIPE Small filler pipe
G605 FUELTANK,CAPACITY Capacity 68 litre, R-LINE
G801 FILLING NOZZLE BIFUEL Without Filling nozzle
G902 FUEL LEAKAGE DETECTION Fuel leakage detection
GA05 EMISSION, EVAPORATION SYSTEM Evaporator system ULEV Prim
GB01 DIAGNOS SYSTEM OBD 2
GKAM EMISSION CODE Emission level Lev2 VIN pos8=7
GM02 LEAD RESISTANT LAMBDA PROB Without lead resistant Lambda sond
GX00 LOAD MODULE ECM Not applicable variant, no parts allowed
IA01 WASTE BIN IN TUNNELCONSOL Without Waste bin in tunnel- console
IB02 WASTE BIN, FIXPOINT Without Waste bin
JA02 MAIN LIGHTS, TYPE USA design
JB10 HEAD LIGHT, SYMMETRY White right assymetrical, 1xH7 + 1xGDL bulb, bezel R-line
JC01 AUTOMATIC DIPPED HEADLIGHT Always dipped headlight exceptin position P. Adjustable
JF03 HEAD LAMP ADJUSTER Automatical headlight adjustment
JG02 HEAD LIGHT CLEANERS Wipers
JJ04 THEFT PROTECTION BRACKET P28 Without protection bracket side door P28
JK00 REAR FOG LIGHT, POSITION Not applicable variant, no parts allowed
JL02 LIGHT SOURCE, STOPLIGHT REAR Light bulb
JS01 REAR FOGLIGHT,TOWFUNCTION Foglights running even when trailer is connected
JT03 FOGLIGHTS,FRONT IN SPOILER Foglights in front spoiler (head light restricted)
K001 MOBILE OFFICE Without mobile office
K161 CASSETTE/CD RADIO Casette radio with CD-play
K205 LOUDSPEAKER PACKAGE Loud speakers side doors,rear shelf
K401 MD-PLAYER P28 Without MiniDisc-player
K501 AMPLIFIER Without Amplifier
K601 CD/MD-CHANGER Without CD cables
K900 TELEPHONE SYSTEM Not applicable variant
KA01 SPEED LIMITATION Speed limitation, 250 Km/h
KB05 INSTRUMENT CLUSTER MPH gradation, USA R-line
KC02 SPEED WARNING Without Speed warning device
KD01 HEADPHONE SOCKETS,REAR Without rear headset sockets
KE03 TRIP COMPUTER Trip computer
KG02 CRUISE CONTROL Cruise control
KH01 REAR SEAT ENTERTAINMENT Without RSE
KI03 TV RECEIVING SET Without TV receiving set
KJ02 BELT REMINDER USA type, incl. key warning
KL01 BRAKE CONTROL Without Brake control
KN01 LOUDSPEAKER,D-POST WITHOUT LOUDSPEAKER D-POST
KO02 LOUDSPEAKER,FRONT DOOR Loudspeakers front side doors
KP02 LOUDSPEAKER,SIDE DOOR REAR Loudspeakers rear side doors
KQ01 MICROPHONE Without microphone
KR02 LOUDSPEAKER,HATSHELF Loudspeaker hatshelf
KT03 PANEL RADIO PREPARATION Radiopreparation in Centrestack VOLVOradio type HU-XXX
KU01 CENTRE LOUDSPEAKER,DASHBOARD Without Centre loudspeaker, Dash
KV04 BASS LOUDSPEAKER LUGG.COMP Without subwoofers lugg.comp.
KW11 CUPHOLDER DASHBOARD Without Cupholder in Dashboard
KX01 RTI/TV DISPLAY,DASH Without RTI/TV display, Dash
KY02 DIVERSITY ANTENNA, BUMPERS Diversity antenna
KZ01 TELEPHONE Without telephone
L002 LOGO, remote control R-line LOGO, remote control
L102 ALARM / REMOTECONTROLES Alarm, 10 alarm cycles
L203 LOCK TYPE,CENTRAL LOCKING 2-Step opening, Central lock
L302 ALARM ACT VIA DOORLOCK Alarm activive with door key
L401 CHILD LOCK Without Electrical child lock
L501 PASSIVE ALARM ACTIVATION W/o automatic alarm activate
L601 RETRIGG ENABLING - IF ALARM Without Retrigg functionality
L802 LEVELSENSOR-IF ALARM Without level sensor
L901 EXTRA EQUIPMENT-IF VGLA Without unique material
LA02 REAR VIEW MIRROR,HEATING Electrically heated mirrors
LD04 REAR VIEW MIRROR GLAS,DRIVER LH side mirror,flat
LE08 REAR VIEW MIRROR GLAS,PASS SIDRH side mirror,radius 1400 english text
LK02 LIGHT IN OUTER MIRRORS Light in outer mirrors
LN02 TRUNK ENTRAPMENT RELEASE Trunk entrapment release
LP01 CIG. LIGHTER/ASHTRAYS Without Cigarette lighter
LQ02 PRIVATE LOCK LUGGAGE COMP. Private lock trunk comp. with disable buttom
LR01 DARKENED REAR WINDOWS Without Dark glass rear
LT01 GLASSBRAKE WIRE/SENSOR Without Glassbrake wire in rear glass
LU01 AUTOMATIC LOCKING Without automatic doorlocking
LV01 MASSMOVEM. SENSOR-IF ALARM Without massmovement sensor
LW01 BLIND SPOT INFORMATION SYSTEM Without Blind spot Information System
LX09 GLASS,REAR VIEW MIRRORS LH side mirror: Flat .RH side mirror: R1400 English text
LY15 FREQUENCY REMOTE-IF REMOTE 315.00 Mhz, High effect with panic function
LZ09 SECURITY PACKAGE Security pagage 9 (lock & alarm)
M102 Memory With memory
M201 Retractable sideview mirrors Without retractable mirrors
M304 Rear view mirrors Memory mirror w/o retractable
M404 Rear view mirrors Memory mirror w/o retractable
M902 DOOR HANDLE, FRONT Door handle, R-line
MB03 TELEPHONE HANDSFREE Without handsfree phone
MC04 COUPEFILTER Air Quality System
MI01 ACKNOWL. SIGNAL LOCK/ALARM LOCK ACKNOWLEDGE (NO UNLOCK)
MN02 FREQUENCY BAND & STEP,RADI Frequency band and step for USA
MO11 LANGUAGE US ENGLISH for instrument and radio
MP02 WALLET CUSTOMER INFO Leather wallet
MR02 AUTO UP WINDOW LIFTS Auto up, front doors
MS05 INSTRUCTIONS Owners manual American/English, no warranty booklet
MT01 INSTRUMENT CLUSTER CALIBR. Parameter file for USA
MU12 SERVICE INTERVAL Serviceinterval 2
N001 SIDE POCKET, TRUNK Without side pocket in trunk
N101 LUGGAGE NET, STEEL Without Steelnet
N201 LUGGAGE NET, TEXTILE Without Luggage net
N401 LOAD HOLDING TRUNK Without Load holding
N505 CHILD SEAT/CUPH. ARMREST REAR Armrest with cupholder
N603 CHILD S-BELT ATTCHM REAR Prepared for child belt attachm,2 plugs
N702 CHILD SEAT ATTCHM Child seat attchm
N801 ATTCHM CHILD SEAT FRONT Without child seat attchm
N901 CHILD SEATS REAR,OUTER Without outer child seat
NA02 DOOR PANEL,FRONT Front door panel, sport
NC24 TRIM PANEL Brushed aluminium
ND01 EXTRA SEAT Without Extra seat
NE00 ARMREST,DOORPANEL-IF LEATHER Not applicable variant, no parts allowed
NF03 HANDBRAKE LEVER Handbrake lever, R-line
NG49 UPHOLSTERY MATERIAL Softleather
NH02 PROTECTION VISOR, COMBI INSTR Protection visor, combi instrument, R-line
NI03 DRIVER SEAT Power driver seat with memory
NJ03 PASSENGER SEAT Power passenger seat without memory
NL01 SEAT HEAT CALIBRATION Without Seat heat
NM01 HEATED SEAT Without heated seat
NO02 HEADREST REAR,FOLDING Electrically foldable rear headrests
NP01 SPLIT REAR SEAT 40-60 split
NQ04 CENTRE CONSOLE FRONT R-line tunnel console
NS01 LOCK REAR FLOORLID Without lockable rear floor lid
NV02 CUP HOLDER,TUNNEL CONSOL 2 cup holders without ashtray
NY04 PROTECTION CARPET SET,COUPE Carpet set, R-line
NZ03 FLOOR CARPETS Floor carpets, R-line
PA02 SUNVISOR, UPHOLSTERY Sunvisor, textil
PB03 MAKEUP LAMP SUNVISOR Illuminated mirror driver/pass
PE01 12 VOLT OUTLET LUGGAGE Without 12V outlet in luggage
PF00 HANDLE TAILGATE 5-DOOR Not applicable variant, no parts allowed
PI03 FIRST AID KIT Without first aid kit
PK02 LOADCOVER,5-DOOR Without rear shelf 5-door
PL01 SUN BLIND,REAR WINDOW Without Sun blind (not executive)
PM01 SUN BLIND,REAR SIDE DOOR WIN. Without sun blind rear sidedoor
PN02 INSIDE REAR VIEW MIRROR TYPE Automatic dimning of inside rear view mirror
PP02 HOME LINK With Home Link
R001 SELF SUPPORTING TYRE W/O self supporting tyre
R148 RIM A 17' 8Jx17x46 R-CAR
R531 TYRE DIMENSION 235/45R17
R609 SPARE WHEEL Spare T115/85R18
R701 LOCKABLE WHEELBOLTS-IF ALU RIMWithout lockable wheelbolts
R817 TYREBRAND Pirelli PZERO
R905 TYRE CIRCUMFERENCE Rolling circumference 1960mm
RA16 CHASSIE TYPE Chassi LOW SPORT, adjustable and active, Four-C R
RB03 ACTIVE SUSPENSION Continious Controlled Chassi Concept, R-line
RC03 BRAKE ASSISTANCE Electrical Brake assistance
RE03 BRAKES,TYPE 17,5 inch brakes, FNR
RF05 ANTI LOCK BRAKE SYSTEM ABS with Dynamic stability traction controle
RG01 TYRE PRESSURE MONITORING S Without Tyre Pressure Monitoring System
RH01 ROADFRICTION DETECTION Without Road friction detection
RI01 LEVELING SYSTEM Without Leveling system
RJ02 EL.VACUMPUMP, REAR BOOSTER Electrical vacumpump
RK04 STEERING WHEEL, MODEL Steering wheel 3 spoke, R-LINE
RL01 WHEEL MATERIAL Aluminium Wheel
RM03 WHEEL, INCH 17' Wheel
RQ00 JACK XC90 Not Applicable RQ
RU02 STEERING WHEEL Steering wheel, leather
RV03 STEERINGWHEEL MODULE Satelite for Audio
RW01 ROLL STABILITY CONTROL Without Roll Stability Control
RX05 STEERING GEAR Steering gear, R-LINE (ZF)
RY01 VIBR. DAMPER STEERING WHEEL With vibr. damper
SC01 TABLE IN REAR SEAT Without table in rear seat
SF02 COMMUNIKATION TAXI Without el-cable Taxi.
T001 EMBLEM REAR LH Belt tongue long
T102 EXTRA EMBLEM REAR RH R-line emblem, rear
T227 ENGINE EMBLEM REAR RH Emblem 'AWD'
T301 DECAL TRIMLEVEL Without trim decal
T401 WATER REPELLANT SIDE WINDOWS Without water repellent side windows
T601 SIDEWINDOWS Hardened side windows
T701 RAIN SENSOR Without rain sensor
T802 WINDSCREEN Tinted windshield with band
TE03 SILL MOULDINGS Sill moulding and lower doormoulding in colour
TG03 SPOILER REAR With rear spoiler
TJ02 BUMPERS COLOUR MATCHED Front for R-line
TK02 NUMBER PLATE HOLDER Number plate holder type USA
TN06 WAIST MOULDING Waist moulding in car colour.
TP02 ROOFRAILS Without roofrails
TS02 WARNING TRIANGLE Without warning triangle
TU01 AIR SEALING Air sealing for R-line
TV02 AIRGUIDE SPOILER Bumper without airguide
TX01 MUDFLAPS,REAR Without mudflaps
TY01 MUDFLAPS,FRONT Without front mudflaps
TZ01 AIR FILTER Airfilter R-line/24HT
UB02 TRANSPORT STRAPS With transport eye
UC01 DIRT DEFLECTOR Without Dirt deflector
UD02 BATTERY MAIN SWITCH With Battery main switch
UE02 BATTERY MINUS CABLE Battery minus cable, new long
VA01 CONTROL UNIT RTI Without control unit, RTI
VB01 CD/DVD-ROM DISC - IF RTI Without CD-ROM
VC02 REM, rear electronic module High spec REM
VD01 RTI SYSTEM (OM RTI) ALT. PREP.Without RTI preparation
VE01 NIGHT VISION Without Night Vision
VF02 AEM PREPARATION AEM preparation (Acessory Electronic Module)
VG01 VOICE CONTROL Without voice control
VH01 INTERCOM Without intercom
VI01 TMC Traffic Message Chann Without TMC
VJ01 GPS Global Positioning Sys Without GPS
VK01 INFOTAINMENT SYSTEM Without infotainment system
VM01 INFOTAINMENT THEFT PROTECTION Without InfotainmentTheft protection
VP04 PARK ASSISTANCE With parking assistance rear (REM)
VR02 SATELLITE PREP. Satillite prep.
XA00 MARKET DECALS/SIGNS Decals for USA
XA02 MARKET DECALS/SIGNS Decals out Japan
XA11 MARKET DECALS/SIGNS Decals out Australia
XA25 MARKET DECALS/SIGNS Decals outside France
XA34 MARKET DECALS/SIGNS Decals for California
XA40 MARKET DECALS/SIGNS Decals outside Canada
XA47 MARKET DECALS/SIGNS Decals Outside China
XB15 PACKAGES FOR PLATES AND DECALSDecals for MC 31
XD01 USER PACKAGES For VEC
XE02 USER EXCEPTIONS Only for VCG
XE03 USER EXCEPTIONS Not for VCT
XE06 USER EXCEPTIONS Not for Thailand
XE08 USER EXCEPTIONS Not for Malaysia
XE11 USER EXCEPTIONS Not for Thai, Mal, Indo, Daqing
XE19 USER EXCEPTIONS Not for Indonesia
XE21 USER EXCEPTIONS Only for ECG
XI02 DECAL FOR TYRE PRESSURE Tyre pressure decal type 2
Y807 VIN pos 4 or 7 VIN-code position 4
Y915 VIN pos 5 eller 8 VIN-code position 5
YA03 Vehicle inspection number YV1
YB05 YEAR DESIGNATION LETTER Year des 5 = model year 2005
YC14 MAX FRONT AXLE WEIGHT 2420 lb, V70 XC 1100 kg (USA)
YD27 MAX REAR AXLE WEIGHT 2310 lb
YE53 GROSS WEIGHT 4540 lb
YF99 TRAIN WEIGHT Without weight
YG24 MAXIMUM LOAD 350 kg or 770 lbs
YH04 TYRE PRESSURE HEAVY LOAD F:270kPa/39psi, R:270kPa/39psi
YI06 TYRE PRESSURE LIGHT LOAD F:240kPa/35psi, R:240kPa/35psi
YJ04 TYRE PRESSURE SPARE WHEEL 420 kPa/61 psi
YL00 SUPPLEMENTSINFO FOR WVTA-NR Not applicable variant, no parts allowed
YM17 TYRE PRESSURE HEAVY LOAD, TPM Tyre pressure warning 41 PSI
YP00 WVTA-NUMBER Not applicable variant, no parts allowed
Old Dec 13, 2018 | 03:06 PM
tkross's Avatar
Where did you find all of that information? I am having the same issue with my VIN.
XC90ChrisP
Sep 10, 2018 08:52 AM
ccmotorsportsohio
Mar 20, 2014 01:44 PM
T5-Rennen
Jan 22, 2013 12:58 AM
biergoat
Jan 30, 2012 10:15 PM
gravedigger
Jul 17, 2010 07:30 AM
