Help with error codes
Hi , ive been getting really helpfull information from this forum which i thank you all and maybe somene can help me out.
i bought my car from the US (Living in Guatemala)
its an S60 2001 non turbo
i got the following errors from a friends scanner.
ECM-4201 three way catalistic converter efficency (power deterioration) , could it be the oxygen sensor? how can i fix this?
SRS 0059 ?? (It didnt gave me any info at all) what is it? how can i fix it?
thanks!
thanks!
Welcome to the forum.
ECM-4201 is stored if the ECM registers that the rear heated oxygen sensor is switching too quickly.
Possible problems are:
1. Air leakage in the exhaust system.
2. One or more damaged injectors.
3. Damaged catalytic converter.
To check for 1 you should have an exhaust pressure regulator which builds up the pressure in the system. The joints in the exhaust between the cylinder head and the rear oxygen sensor are then sprayed with a soap solution to find out if there is a leak.
The other two are self explanatory.
The SRS code can only be cleared by a dealer as it relates to the airbags etc.
thanks for the usefull info.
a mechanic told me he could take out the catalyctic converter to get it clean , that it could be that its only dirty inside. Do you think that could help?
bad injectors that sounds expensive , do you have a link to that part to buy them?
thanks
thanks
I have never heard of cleaning the cat converter.
You might have to buy the injectors new from a Dealer. I am not sure who sells them aftermarket.
I have done about 100 of these cars with that code and the injectors fixed it. But if it is left to long without being fixed the cat will go bad and need to be replaced as well.
thanks tech , you know i got this errors as well
SRS 0007 collision signal fault signal , permanent
0064 front left seatbelt tensioner
006c front right seatbelt tensioner
0059 wich gave me no info
i do have both seatbets blown , my questionsis if i replace both seatbelts and erase the errors with the scanner will that fix the SRS error? or is there something else i need to replace?
thanks for all the help
You might have to replace the crash sensor as well. But I would replace the parts and try first. I would say you have a 50/50 chance.
I have seen it go both ways.
