Help with MC pressure sensor connectors
I’m replacing the brake booster and master cylinder on my 2007 S60 (has DSTC). Does anyone understand how to remove the connectors on the brake pressure servos on the bottom of the master cylinder? I Need to disconnect these so I can remove the pressure servos from the MC (which requires a 27mm socket). Thanks!!
Pretty obvious once you pull the master cylinder. Use a dental pick to lift the tab and slide off the connector.
