Help with MC pressure sensor connectors
Old Aug 28, 2019 | 04:09 PM
VeroS60's Avatar
Default Help with MC pressure sensor connectors
I’m replacing the brake booster and master cylinder on my 2007 S60 (has DSTC). Does anyone understand how to remove the connectors on the brake pressure servos on the bottom of the master cylinder? I Need to disconnect these so I can remove the pressure servos from the MC (which requires a 27mm socket). Thanks!!
Old Aug 30, 2019 | 02:18 PM
VeroS60's Avatar
Pretty obvious once you pull the master cylinder. Use a dental pick to lift the tab and slide off the connector.
Twiztedvolvo01
Jun 18, 2017 07:25 AM
kennedy759
Feb 4, 2017 09:59 AM
Ben_25
Oct 28, 2016 05:56 PM
Xoloski
Sep 27, 2014 08:25 PM
suter
Nov 22, 2006 09:13 PM
