HID Lights
Hi
I have a 2001 S60 2.4T and just had HID lights installed, the problem is that I get the Dip Beam message. I called the dealer (the lights were not dealer installed) and was told that its because the computer doesn't recognize the lights. He told me there was no way to fix it and there was no reset for it. I find that hard to believe. Is there anyone else with this problem? Any feedback would be appreciated. Thank you.
I have a 2001 Volvo S60. I installed a aftermarket HID kit. I hooked everything up and it all ran fine for a couple days and I noticed after that the passenger side ballast burnt out twice on me. So I figured to give a HID relay kit a try. I hooked up the kit and now my car starts up stronger and feels stronger with the relay kit hooked up. I now have a new problem, I have a low beam dip failure message that will not go away. The little orange warning light right in the middle of the dash will also not go away. I tried doing the trip reset, and unplugging the positive and negative terminals on the battery and holding them both together for 5 minutes and nothing has worked!?!? Is it possible to make the HID's work with the relay kit? Up the amps, fuses? Does anyone have similar issues or think they might have a answer to this? ANY INPUT WOULD BE GREATLY APPRECIATED. THANK YOU SO MUCH AHEAD OF TIME
Read this.
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} http://www.hondaforums.com/index.php...D=28493Regards
That is for the bulb failure message.
Ive got the same problem but I did not drill a hole into the computer module. Its as simple as getting different resistors that draw more current, therefore eliminating the error message. Its cheaper to drill the hole but personally I would rather pay the money for resistors so everything is done properly and you can be worry free.
Im not sure what your HID kit looks like, but i purchased mine from euro sport, the ballast has to lines going in/out of it. One is connected to the ballast already and the other is a more rectangular shape with rounded edges hole where the resistor clips in. My Kit came with resistors but they did not keep my dashboard from lighting up. Frank contacted the company for me and they sent him a pair of resistors saying that they had an s60 in there shop and these resistors fixed the error light. If I were you I would call or email Frank at euro sport im sure he can do something for you, he provides great service.
www.eurosporttuning.com
You should be able to find his email address and phone number on there.
Best of luck with getting it fixed
To be honest I'm not sure if I am ever going to get around to doing this due to lack of experience with this kind of stuff. I appreciate all the help you have given though.
Count Chocula
Feb 3, 2013 07:46 AM
asudan
Mar 1, 2007 02:05 AM
