High Pitched Moaning Noise?
Hello folks,
My 2001 S60 T5 has 152,000+ miles on it...it has the automatic transmission. Upon accelerating from a stop, I get a high-pitched moaning noise up to about 10 to 15 mph. A/C is off and it happens whether I'm going straight from a stop or turning from a stop. Any ideas? And apologies if this was addressed somewhere else previously.
Thank you!
Thank you!
Actually, I found out its the front brakes - pads and rotors due after 60+K miles on them.
But thank you for the tip on the wheel bearings. That was the next noise I was going to ask about here. Because that's the higher pitched whine I hear at all speeds that sounds like its coming from the rear wheels.
Its an easy fix?
Its an easy fix?
Its an easy fix?
Its an easy fix?
so your brakes were binding? what exactly was going on with them?
99s7o
03-17-2011 08:55 PM
