how can i remove the cpu without tool
Old Dec 24, 2008 | 09:33 PM
01VOLVOS60T5's Avatar
Default how can i remove the cpu without tool
need some hint to remove the two computers on the plastic box, i cant remove it, seems to be lock it., can be removed without tool, how?
Old Dec 24, 2008 | 09:44 PM
Default RE: how can i remove the cpu without tool
It is a pain to do but can be done.
If you remove the black ECU box top half and middle half (Clips hold it on) then you will see purple pieces on the sides of the computer. You will need to slide them back with a skinny long screwdriver. There is 2 per computer. You have to slide each side a little at a time till they come loose.
fiey24
Mar 24, 2014 07:21 AM
pantenor
Feb 3, 2012 09:43 PM
xxblindxx
Sep 25, 2011 05:47 PM
ruggles
Jan 16, 2010 03:41 PM
Mandy
Apr 29, 2009 11:23 PM
