How many quarts of 5W30
Old Oct 7, 2021 | 02:50 PM
JazRay57's Avatar
Default How many quarts of 5W30
Can anyone tell me the oil volume of a 2.0 liter 4 cyl 2016 T5 Inscription? Is it 7 quarts?
Thank you!
Old Oct 7, 2021 | 04:16 PM
Interesting that the owners manual lists the oil specs but not the capacity. Amsoil's web site lists 5.7Q with filter. Note the manual says to always use synthetic and shows 5-30 as standard weight, 0-30 for extreme with 0-20 only for the 4 cylinders. They also recommend Castrol Edge as the factory oil but lists the specs to meet. You can also call the dealer about capacity and weight. There was a recent post which suggested their dealer told them "they only stock 0-20" so I'd be curious what you're told. As always, after you change the oil, check for leaks and then check the fill level and a second time after a short drive.
Old Oct 7, 2021 | 06:58 PM
ES6T's Avatar
Zero.
The 2L should be getting Volvo spec 0W20.
Link2020
Oct 8, 2021 12:59 PM
JazRay57
Oct 7, 2021 04:10 PM
Kathleen Kahl Stetson
Mar 4, 2019 07:16 PM
brownbrad
Jul 16, 2016 03:06 AM
