I got a S60R
Old Sep 29, 2006 | 12:54 AM
Schu727macher's Avatar
Default I got a S60R
What can I do to my s60R to upgrade the power?
Old Sep 29, 2006 | 10:04 AM
S70driver's Avatar
Default RE: I got a S60R
1. Search before asking what mods are worth it.
2. What is your budget like?
3. What is your Hp goal?
Old Sep 29, 2006 | 10:36 AM
S70driver's Avatar
1. I would suggest doing a complete STAGE 0 (Stage Zero). If you don't know what that is become a member of Volvospeed.com and or click here. Stage Zero
2. Get a boost gauge. Egauges They sell them at good prices. As far a a pod goes I don't think anyone makes a gauge pod for the s60 range of models. So find another way to mount it.
Old Sep 29, 2006 | 01:38 PM
S70driver's Avatar
I will tell you this. DO NOT, I REPEAT DO NOT use a MBC (Manual Boost Contoller). ME7 cars do not like MBC's.
Old Sep 29, 2006 | 01:51 PM
S70driver's Avatar
How far do you want to mod your car? I mean do you want to upgrade your turbo to something bigger? Do you want to upgrade your intercooler, injectors, etc...?
Old Sep 29, 2006 | 02:31 PM
S70driver's Avatar
After you have done the Stage 0 and the boost/vac gauge this is what i suggest.
1. Have a 3" downpipe and 2.5" free flowing catback with a Magnaflow muffler. All mandrel bent of course. Now if your going to upgrade your turbo to something bigger then you would want a 3" downpipe and a 3" catback system.
You could go with a prefabbed downpipe and or catback system but that is $$$$, and having a whole exhaust system custom made can be had for around $800-$1000. Instead of just spending $750+ for just a downpipe and then another $300+ for the Catback system.
On my 1999 s70 awd I was quoted about $600-$800 for a 3" downpipe to a 2.5" catback system.
2. Intake, EST makes one but it is mainly an HAI (Hot Air Intake) EST's Intake
Ipd also has a filter for the R's as does EST.
EST filter
IPD's Filter
The stock airbox is the best setup IMO and a lot of other people will say the same thing.
3. ECU upgrade. IPD, RICA, BSR (These are the companies I would go with). You can also look into Upsolute, SpeedTuning USA. These will raise your boost and this is why you should have a boost/vac gauge. Also you should do this after you have installed the Intake and Exhaust system.
BTW: You should dyno your car stock and get A/F ratios. Then when you upgrade the ECU lets say with RICA send them those stock dyno figures and A/F ratios. Also dyno with the downpipe and catback system and Intake. And send them to them as well. So they can see the difference between stock and partially modded. This will help them tune your ECU better.
TacklaNHL
Jan 19, 2013 03:26 PM
Ken R
Apr 14, 2011 03:09 PM
Never-Enough
Feb 28, 2011 09:49 PM
Schu727macher
Sep 29, 2006 10:32 AM
jersey girl
Sep 24, 2004 12:37 AM
