I have a 2002 S60 with a bad idle
Old Sep 5, 2020 | 04:53 PM
iconzpres's Avatar
Default I have a 2002 S60 with a bad idle
My S60 has a rough idle. I installed a mass airflow sensor and still has rough idle. When I unplug the mas it gets better. It does still have an irattic idle. It also now has a slow response at first acceleration. What should I be checking for? I thought maybe the tps but I don't want to buy one unless some tells me to. Any ideas?
Old Sep 5, 2020 | 06:42 PM
Your first step should be a scan with VIDA - the stolen/hacked software is free, a cloned chinese dice unit is ~$80
Or - randomly buy and replace parts hoping what you are doing will fix something -
Rough idle could be a misfiring cylinder - what codes are stored?
Old Sep 5, 2020 | 07:42 PM
iconzpres's Avatar
No codes appear although the check engine light is on.
Old Sep 5, 2020 | 07:56 PM
If the check engine light is on - there are codes, just whatever you are using can't read them - VIDA can.
Old Sep 6, 2020 | 02:25 PM
what device did you use to scan for codes? I'm pretty sure the 02s had moved to the CAN protocol but even my $29 Harbor Freight can read both CAN and ISO9141. Just make sure to plug your reader into the port with the key off, then turn the key to position 2 (dashlights on, engine off). You'll see it communicating and indicate if any codes have been found. unplugging the MAF would surely set a code so at least that one should be found.
SuperMario811
Oct 30, 2017 10:02 PM
Michael Moser
Oct 21, 2012 10:39 PM
pentech
Jun 27, 2012 05:37 AM
ssvo
Jun 27, 2011 11:54 AM
96850urbo
Aug 3, 2009 12:07 AM
