I have a leak!
That's not uncommon but not enough to cause what you are seeing below. The rear of the head is basically the driver's side the way it sits in the car. If the can seals aren't leaking, it is probably the rear main. You should also make sure the breather box isn't clkgged, causing the leak. If there is positive pressure from the dipstick, replace the breather box and clean the ports on the block from the breather box and verify slight vacuum from the dipstick. Then clean off the oil and hope the seal isn't permanently leaking.
poor_red_neck
06-27-2010 09:03 PM
940glowner
04-22-2010 12:08 AM
