Interior lights flickering
Old Feb 15, 2012 | 10:38 PM
LAS60's Avatar
Default Interior lights flickering
2009 S60 2.5T, when car is at idle the interior dome light flickers. I checked to volts on the battery and it was okay, car is over 3 years old so installed new battery and this did not help.
Any ideas, or is this normal???
Old Feb 21, 2012 | 03:28 PM
hickman123's Avatar
maybe a diode out in the alternator i would have it check before replacing or see if the ground or power varies to the ground or power of the lights at idle for some reason. there is a tsb if you have aftermarket electrical stuff it has to be grounded after the battery monitor sensor. it says it can reduce alternator out put.
jpirish
Dec 18, 2021 01:24 PM
DDBrown
Dec 8, 2017 11:01 PM
cb1313
Dec 21, 2012 04:10 PM
codj2k
Nov 6, 2012 06:16 PM
mfrancis
Mar 1, 2012 10:46 PM
