LOUD NOISE '03 s602.5awdT
I recently purchaed an '03 s60 2.5 AWD T. It has 44,000 miles and operates great. The other day we had approx. 1-2 inches of snow and the roads were covered with snow and slush. The first time I have operated this car in those conditions. After about 2 miles there was a very high-pitched sound like metal- on -metal coming from the rear. It would subside in lower speeds, but regain pitch at about 30 mph. Now that the roads are clear, the sound has disappeared. Thoughts?
RE: LOUD NOISE '03 s602.5awdT
More snow in SE WI so I took the car out to see if I could replicate the sound. With about 3 inches of snow on the road, the noise came back. I will say that the car was less stable on the road than I previously posted. There was slippage,but not awful. Since thisis my first AWD, I am not surewhat to expect in relatively extreme conditions. Could the TRACTION CONTROL be out/malfunctioning and if so, will this be the cause of this extremely high-pitched sound? It should be noted that the sound goes away when travelling under 20 mph. Any ideas on next steps, expected costs, etc.
There is no recall it is a TNN, Whe the exhause heats up and then gets a splash of rainwater or snow on the exhaust it causes it to rub the driveshaft causeing a loude squeeling noise, There is a updated exhaust hanger for this, if you look under the car right before the rear wheels you'll see a ring around the driveshaft, thats your noise..
no big deal, just annoying..
i think the exhaust bracket is about 80$
