Low Idle *650 rpm
Old Nov 27, 2011 | 08:55 PM
Nichals's Avatar
Default Low Idle *650 rpm
ive been having a lot of shaking latley in my 2004 s60 2.5t
i dident pay it too much attention but my rpm is at 650 + or - 20
is that normal? i thought it should be at about 850 and if so what would cause the idle to be so low?
Old Nov 28, 2011 | 05:35 PM
fcpgroton's Avatar
Former Sponsor
Nope, it should be higher then that. I would start checking for vacuum leaks.
Old Nov 28, 2011 | 05:55 PM
Nichals's Avatar
so 850 is where I should be sitting at
this would explain why I've been having such a problem
looking at the hoses and tubes specifically around the throttle body there is quite a bit of oil coating the inlet hose
it was dark so all I could do was try to tighten the hose clamp to no avail
Wednesday I'm going to take it off and inspect it along with the other lines
are there any specific arias I should be looking?
Old Dec 2, 2011 | 05:50 PM
Nichals's Avatar
ok here it goes
cleaned MAF sensor
resealed all connections on all vac lines
replaced spark plugs
replaced angle position sensor
seafoamed everything
the car is now faster than the day i bought it!
Old Dec 13, 2011 | 10:50 PM
Nichals's Avatar
car still running great
still "low" idle or what i thought until i found this in VADIS
Old Feb 25, 2022 | 08:11 AM
Vageloudalis's Avatar
OMG searching for that about pne year!!
I thought my 2.0 t5 had big.problem bcz idle was on 670 rpms.
Thanks!
Old Feb 25, 2022 | 09:30 AM
check out the xemodex web site for some diagnostic procedures on the ETM
https://xemodex.com/us/product/elect...epair-service/
tnburban
Jul 12, 2014 12:24 PM
nkinkade
Feb 28, 2014 08:49 PM
afmattgto
Sep 21, 2009 01:42 PM
elderzap
Nov 7, 2007 04:58 PM
