Lower brake lights out, fuses and bulbs are OK
Old May 26, 2006 | 11:40 PM
  #21
Default RE: Lower brake lights out, fuses and bulbs are OK
Are you 100% sure you are looking at the U.S. Diagram?
Im not sure other than that.
Old Oct 26, 2007 | 04:40 PM
  #22
luvmy01wrx's Avatar
is there a solution yet for this problem. I have the exact same problem
Old Oct 26, 2007 | 07:34 PM
  #23
There has been a rash of this lately.
It is turning out to be a bad relay in the rear fuse panel.
It is one of the small rectangle relays.
Sometimes you can touch it and the lights will start working.
Old Oct 26, 2007 | 10:49 PM
  #24
luvmy01wrx's Avatar
Cool I hope thats it. The cars actaully a customers car. I tried to additional led lights. The customer asked for them cause hekeeps getting rear ended & now that I tried to hook up my led's the lower break lights dont work anymore.
Old Oct 26, 2007 | 11:46 PM
  #25
If wiggling it won't work let me know and I will get the relay location for you.
Old Aug 12, 2009 | 01:29 PM
  #26
khiattjr's Avatar
Default How I fixed this...
I had the same symptoms: "CHECK BRAKE LIGHTS" warning light on when brake pedal depressed; fuses OK; bulbs OK.
A local tech did a quick diagnostic and told me to order a new turn signal switch, since all of the wiring goes through the switch. I was skeptical, but ordered the $83 part.
When I brought the car in to have him install it, he plugged a computer into the car, which gave him a REAR ELECTRONICS MODULE (REM) failure code, so he told me to return the switch and order an REM from Volvo.
I called a Volvo shop, and they said that in 15 years they have NEVER seen an REM fail, but they do sometimes "fall asleep" and need to be woken up. The problem could also be with the brake light relay. would be $89 to "wake up" the REM, or less if it turned out to be the relay.
Voila...it was the relay! The relay is one of the cube-shaped relays plugged into the board on the left side of the trunk. Only $67 to replace, with labor.
Old Jan 9, 2011 | 01:10 AM
  #27
hookahtimez's Avatar
Default Hookah
hey ever try out a hookah? <a href="http://hookahx.com/">Hookah Pipes</a>
Old Jan 25, 2011 | 09:13 AM
  #28
DxSEO's Avatar
Default Just Wana Say hi to all
hi i am new here just wana say hi to all DxSEO
Old Nov 13, 2012 | 12:45 PM
  #29
fatcatusn's Avatar
How do I get to the lower brake light bulbs? I'm trying not to break anything.
Old Apr 14, 2013 | 07:18 PM
  #30
rjgsr13's Avatar
Tech is there a fuse box located in the trunk? I have a 00 s40 with the passanger side break light out. I changed both bulbs and still the passage side will not work?
Old Sep 21, 2015 | 02:48 PM
  #31
EllaWood's Avatar
Default ?
Originally Posted by AR
As the title says, my brake lights are out, and the console is throwing the "Check brake light" error.
Bulbs have been replaced, mechanic said they were good, and old ones were definitely blown. Fuses are good -- replaced them anyway, still no go.
The brake light at the top center of the glass works great, just the lower taillights.
Any ideas of what to specifically look for? The mechanic is not Volvo-specific or trained, so he will not be working on the car.
Thanks!
I'm having same issue with my 04volvo s60..ever figure out the issue
Old Sep 26, 2015 | 12:05 PM
  #32
pjsmithres's Avatar
Although I'm new on this forum, my 940SE had this problem.
Please check the blub body.
Although they are new, there are nickel (silver colored) and brass (gold colored).
The 940 had a problem with light was good and gave warning in the dash that bulb was out.
I talked to a volvo parts guy and some Volvos don't like brass bulbs. I can't figure out what is different, if they all are conductive, but after changing to the nickel colored body, the problem has been solved.
Hope it helps.
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
SlikRick
Dec 9, 2013 02:57 PM
Akaly
Jun 29, 2011 12:09 PM
jajulian
Nov 30, 2010 09:59 AM
