lower control arm and ball joint replacement
Old Nov 26, 2016 | 07:44 PM
kylecallahan's Avatar
Default lower control arm and ball joint replacement
I've been working on my '01 S60. Removed and replaced drivers side lower control arm and ball joint with no issues. Raised passenger side, removed caliper, ABS, and tie rod nut. When tie rod is disengaged, the hub wants to swing hard right or left, but will not just hang loosely like the drivers side hub did. seems like the strut is pushing out hard causing the hub to turn. Has anyone seen this situation before, and know of a solution? i suspect that i should have raised both sides of the vehicle as the sway bar may be exerting pressure on the strut thru the passenger side end link.Would greatly appreciate any input.
Old Nov 27, 2016 | 03:33 PM
Cookie-The-Swede's Avatar
I would put it up on jackstands. One on each side and of the same height.
When the sway bars are torqued the suspension and steering components do weird things.
dpvovo
Feb 18, 2019 07:41 PM
urdrwho
Jan 17, 2015 07:25 PM
Disco2
Nov 24, 2013 08:25 AM
ecberr
Dec 15, 2009 09:05 PM
Super20
Jun 26, 2007 06:16 PM
