Misfire volvo s60 2002
Old Jun 25, 2019 | 02:01 AM
jorge117's Avatar
Default Misfire volvo s60 2002
Hi im writing you all to see if someone can help me. Im experiencing a misfire in my volvo so i decided to take it to the mechanic. He put a scanner and it was giving a code that was telling that one of my ignition coils was failing. So i decided to have that check and when they checked they find out that the sparkplugs and ignition coils has engine oil all around them. So they remove the valve gasket cover and find out that some o rings around the spark plugs was damage and they replace them. Now i dont have any oil leak to the sparkplugs or ignition coils but im still experiencing the misfire. The mechanic sugested that it could be a problem with the cables that connect to the ignition coils. I will take it to an electromecanic but before that i would like to know if there could be another cause for that misfire. (Ignition coilds and sparkplugs was replace too during the repair) sorry for my bad english.
Old Jun 25, 2019 | 01:35 PM
with the oil cleaned up, new spark plugs and new coils, the only remaining possible cause is the wiring harness to the coils. Check the connectors to make sure there are no cracks and they seat and connect properly. You may be able to clean and seal the connectors but it may be better to invest in a new harness. I just did this for my 00 S40
jeropon
Aug 9, 2016 11:05 PM
mcnabbr1
May 4, 2016 03:37 PM
RJSV70
2001-2013 model year V70
Jun 16, 2013 08:02 AM
NFrank89
May 25, 2011 05:21 AM
Dick2611
Jan 27, 2009 09:44 AM
