Overheating Don't Know Why
Old Jul 16, 2020 | 11:14 PM
Philip Berg's Avatar
Default Overheating Don't Know Why
I have a 2001 s60 2.4t and I can figure out why its overheating intercooler and radiator were replaced within the last year, replaced the reservoir, replaced reservoir cap twice, replaced thermostat twice, replaced temperature sensor, water pump is working and not leaking or making any noise, radiator fan is kicking on like normal, flushed and put brand new coolant in twice, and no coolant leaks of any. Only thing I can think of at this point is cracked block or a blown head gaskets if anybody has any ideas feel free to let me know.
Old Jul 17, 2020 | 11:19 AM
ChopperMan's Avatar
How do you know it's over heating? Gauge? Boil over with visible coolant? Loosing coolant without a puddle? How's the oil look, milky? Have you done a coolant pressure test?
Old Jul 17, 2020 | 03:05 PM
The gage pings red and coolant boils and sprays out of the cap and the oil looks good
Old Jul 17, 2020 | 03:33 PM
there are a few ways to test. First does the heat come on full blast? How long does it take to overheat (google for ways to test if the water pump has failed internally). If you suspect a headgasket issue, you can measure the cooling system pressure - should be something like 1.2 bar or below - plus if you are getting combustion gasses into the coolant, there's HC test kits ~$40 at Autozone etc.
At this point I would not assume that the water pump is working properly. I think its reasonable to test for a failed head gasket issue via a coolant HC test and possibly a leak down test. Also test for the cooling system pressure to see how quickly the pressure goes up and what it maxes out at...
John Dooe
Engine & Internal
Jul 5, 2019 09:15 AM
hillbillybuddha
Oct 6, 2011 03:03 PM
welnamark
Aug 17, 2010 12:47 PM
ajju_kwt
May 11, 2007 04:52 AM
johnnybravo
Engine & Internal
Apr 4, 2006 01:25 AM
