P0068 MAF/MAP Error Codes Followup Question
Old Feb 27, 2012 | 11:51 PM
MarksS60's Avatar
Default P0068 MAF/MAP Error Codes Followup Question
Now that I think I may have fixed my badly shifting tranny with a full ATF flush, onto the next problem.
I have had this error code for a few weeks now, car runs ok, just idles high sometimes and has stalled on a few occasions after driving at highway speeds then stopping at an off ramp.
I cleaned my throttle body and MAF sensor, don't think it helped much.
The way I understand this error code is a disconnect between the MAP or MAF and the throttle positioning sensor, so it could be either part.
Is there a definitive way to check which sensor needs replacing, the MAP, MAF or TPS?
Thanks,
Mark.
Old Feb 28, 2012 | 05:20 PM
Nichals's Avatar
MAF is easy, unplug it and run the car. if it runs better than its likely bad.
there are youtube videos on the other two sensors
you need a multi meter tho
Old Mar 10, 2012 | 12:01 PM
MarksS60's Avatar
Default Do I even have a TPS
Took a look around the engine to take out the TPS to test it, but not sure my S60 even has one? I don't see anything that looks like a TPS and notice none of the online parts sites sell a TPS for a 2002 S60, does that mean it is just built into the ECM?
Thanks.
Old Mar 10, 2012 | 01:06 PM
Nichals's Avatar
the TPS is part of the ETCM (electronic throttle control module) if you take out the throttle you will see a black plastic cover its under there, so in short its not a replaceable part you have to replace the whole electronic throttle. however i belive there is a recall on some of those so it "might" be free for you
Old Mar 14, 2012 | 03:20 PM
MarksS60's Avatar
Thanks.
I found out that the ETCM was replaced already under recall a few years back (before I had the car).
Quinn
Jul 25, 2013 12:08 AM
peterz
Oct 23, 2010 05:47 PM
RobOrtiz
Jul 3, 2009 02:15 PM
98xc70nny
Sep 26, 2007 11:18 PM
khesser
Jul 2, 2007 11:37 AM
