P00BD00 - Help Please need advice
Hi I have a Volvo S60 2011, and just before Christmas I had to replace the head due to aux belt snapping and wrapping itself around the cambelt. Since the car has been back together Im getting a code "Engine Service System Required" and when I put Vida on it comes up with P00BD00 Mass Airflow Sensor Bank A High..
Heres what I've done so far
1. Done a smoke test on air intake - No leaks
2. Done vacuum checks on all pipes - No leaks
3. Replaced the MAF sensor - No different
4. Replaced the MAP sensor - No different
5. Checked Intercooler Pipe - No leaks
6. Replaced Turbo Boost control valve - No different
7. Replaced Fuel filter
I even took the car into Volvo, they tested the wiring, smoke test and vacuum check - Nothing..
After the car has been reset and when its cold the car drives normal with plenty of acceleration, but once the car warms up and after approx 3 miles the car engine service light comes on and goes into limp mode, but If I drive very light footed the cars ok..
I'm at a loss and cant think of anything else..
Any help on this would be greatly appreciated..
