P0303 code, misfire
Old Apr 23, 2013 | 11:24 AM
jons_wifey's Avatar
Default P0303 code, misfire
So hubby's volvo is still getting the P0303 mis fire from the scanner, he has already changed the 5 spark plugs, what's next to change? the coil packs?
he ordered this one, but he told me it didn't fit?!
Brand New Ignition Coil Pack / Pencil / Coil On Plug Oem Fit Complete C341 : Amazon.com : Automotive Brand New Ignition Coil Pack / Pencil / Coil On Plug Oem Fit Complete C341 : Amazon.com : Automotive
Last edited by jons_wifey; Apr 23, 2013 at 11:28 AM. Reason: added relevant extra info
Old Apr 23, 2013 | 12:15 PM
01_fast_ride's Avatar
I just looked back at your previous thread regarding the misfire. I should have suggested to you to FIRST try swapping the #3 coil (suspect) with one from another (good) cylinder. Then reset the code and see if the misfire is still on #3 or moved to the other cylinder. If the misfire is on the other cylinder, replace the bad coil. If the misfire stays at #3, then it wasn't the coil. That's basic troubleshooting 101, and I don't know why I didn't tell you that from the get-go.
bryants40
Jun 7, 2016 01:48 PM
bryants40
Mar 10, 2014 05:26 PM
bringit8435
Dec 6, 2012 02:01 AM
schmuecker
1998-2000 model year V70
12
Jul 27, 2012 01:26 AM
zerofallout
Oct 27, 2010 06:11 AM
