P2 Volvo s60r 2006 Need help!!
Old Oct 30, 2022 | 06:22 PM
Problemcar's Avatar
Default P2 Volvo s60r 2006 Need help!!
So I just bought a 2006 volvo s60r and threw it in a encore obd2 reader and I got tons of codes thrown at me it does have BC coilovers instead of the 4c struts along with a leaky catback exhaust just need help on where to start with these codes also the past owner cut the wires that used to connect to the 4c struts instead of just disconnecting them and the car is giving me 4 constant messages and 1 on and off message 1. SRS-Airbag service Urgent 2. Anti-skid service required (comes on and off) 3. Park assist service required 4.Time for regular maintenance (won’t let me reset even when I change oil/tranny fluid) 5. Chassis settings service required but even with these codes the car still runs fine not in limp mode awd works perfectly and breaks are perfect, please message me and lmk where I can begin with fixing up my car
Antilock break system
0136 break pressure sensors 1 and 2
0130 break pressure sensor 1
0133 break pressure sensor 2
0061 break discs
0140 pedal pressure sensor
0103 pedal position Sensor
Engine control module
434c fuel tank system leakage
accessory electronic module
DD50 communications with SWM control module signal missing
8f12 CEM beam adjustment
8f18 Xenon lamp left
8f1c Xenon lamp right
1a59 communications with AUM control module
1a51 communications with SRS control module
1a52 communications with DDN control module
E001 control module communication
Df07 CAN low speed net work faulty signal
1a56 communications with DIM control module
1a53 communications with PDM control module
1a54 communications with PSM control module
1a5a communications with REM control module
Df03 CAN-F low speed network
Suspension module
0143 suspension solenoid, right rear missing
0013 suspension acceleration sensor front left signal missing
0023 suspension acceleration sensor front right signal missing
0115 shock, absorber solenoid front left side current too low
0113 suspension solenoid, front left missing
Selection
Jun 3, 2020 06:13 PM
Mischief Craig Jones
Sep 17, 2018 02:21 PM
Rdhcincy
1998-2000 model year V70
May 14, 2012 01:29 PM
cdarkoh
Sep 24, 2011 12:21 PM
ckpaden
May 30, 2011 11:45 AM
