Passenger door lock knob broken or loose
This past weekend I noticed my passenger door lock knob was not going up or down when I locked/unlocked the doors. It actually does not appear connected to anything, as I can press it down into the door, or lift it way out. The door is locking and unlocking fine.
Anyone experienced this before? Is this something I could reconnect myself? thanks |
can you pull it all the way out? no matter what you will have to remove the door panel to repair. if you are not intimidated by this, it should be an easy repair.
Originally Posted by peetnik
(Post 240851)
I tackled this last night....it was a really simple problem: the rod had become unattached from the mechanism. No idea how, but I simply snapped it back in and put the panel back on. The connection did not inspire me with confidence, however. If it comes loose again, I'll probably put a drop of glue on the connection.
(Post 241297)
