Passenger door lock knob broken or loose
Old Oct 19, 2010 | 09:30 AM
peetnik's Avatar
Default Passenger door lock **** broken or loose
This past weekend I noticed my passenger door lock **** was not going up or down when I locked/unlocked the doors. It actually does not appear connected to anything, as I can press it down into the door, or lift it way out. The door is locking and unlocking fine.
Anyone experienced this before? Is this something I could reconnect myself?
thanks
Old Oct 20, 2010 | 07:58 PM
titaniums6025t's Avatar
can you pull it all the way out? no matter what you will have to remove the door panel to repair. if you are not intimidated by this, it should be an easy repair.
Old Oct 21, 2010 | 09:39 AM
patsfn2's Avatar
thanks
sounds like your actuator which works that particular lock has gone bad, if you are able to lock and unlock your door but when you use your keyless remote or the switch inside the car and the other doors are locking when you do this, then the actuator for that particular door is 1 of 2 things...1) gone bad, or 2) the rod for that door is not attached to the mechanism is which case you will have to remove the panel on the door to see! please post your findings good luck
Old Oct 22, 2010 | 11:32 AM
peetnik's Avatar
I tackled this last night....it was a really simple problem: the rod had become unattached from the mechanism. No idea how, but I simply snapped it back in and put the panel back on. The connection did not inspire me with confidence, however. If it comes loose again, I'll probably put a drop of glue on the connection.
Old Oct 22, 2010 | 12:10 PM
patsfn2's Avatar
very good....I told you it was 1 of 2 things, with that having been said and the fact that the rod had come loose from the actuator you may have an issue with the piece that holds the rod in place having a stress crack in it and if it cracked the rod will have a tendency to come loose...I if does again you may want to use some safety wire and glue I don't think the glue itself would hold! good luck and glad you fixed your problem.
rspi
May 27, 2013 02:22 PM
dafemrite
Aug 13, 2011 01:12 AM
KONE
Jul 11, 2010 09:24 PM
Karnage
Oct 28, 2009 02:38 AM
jonnybobs
May 30, 2008 07:59 AM
