Please help 2013 Volvo S60
yep.. sounds like a misfire - most likely cause is a coil gone bad, particularly if the car seems to run normal when you are light on the gas. You can borrow a code reader from an Autozone or find a friendly shop who'll scan the codes for free. Takes all of 10 minutes. All you do is plug the code reader into the port that's usually under the dash - kind of looks like an old school printer port on a computer. pop on the code reader, turn the key to position 2 (no need to start - just get the dash lights on) and the reader menu will guide you. Misfire codes will b P0300 (generic/multiple) P0301 (misfire, cylinder 1).... P0305 (misfire cylinder 5). If you have a single cylinder misfire, time to get a new coil :-)
