Poly or OEM Motor mount bushings?
Well, along with my front control arm bushings, my motor mount is shot as well. Not surprising at 100k for the round bushing in a 2001 S60. I have an automatic, and I keep hearing mixed things about the poly bushings. How bad is the vibration with the IPD poly bushing? That's the cheapest and easiest fix. My second choice is to buy the whole assembly with the new square bushing. Either should last me longer than I'll keep the car, but the whole mount will cost a little more (and take more time?).
Thoughts? |
The Idea for the poly is to hold up more hp/tq and have a longer life. You will feel more vibrations since the motor will basicly be sitting on super hard ruber which rests on the frame. So if you dont want to feel any more vibrations, then just get stock.
Originally Posted by TIPSP
(Post 148288)
I look at it for its long life, and if it is cheaper, then why not. I thought the new engines where smoother than say my old redblock?
I have seen alot of poly bushings fall apart as well.
Originally Posted by tech
(Post 148383)
(Post 148383)
I will take pics the next time I see one.
I havae 2 for my car and not sure if I want to put them in. I have a Yellow one and a Blue one. |
if you like I can show you how easily the poly bushing falls apart.. Happened to mine on my s80 within 6 months of putting it on...
Now I have to change it again https://volvoforums.com/forum/showth...ighlight=mount see on the s80 and tell me what you all think.. Its possible it was not torqued in enough but that still is a very very quick breakdown.. Was put on in May, car wasn't driven more than 20 miles during the summer.. started back driving august, and by end of october it was shot. Basically 2 months of driving did that.. |
