Power Steering Issue
Old Jul 15, 2009 | 04:49 PM
borrone821's Avatar
Default Power Steering Issue
Hey Guys,
I've got an 02 S60 T5 with about 220,000 miles. Over the last 9 months or so, the steering has been getting progressively worse. For a while it was just temporarily hard to turn, like every now and then the PS wouldn't work. Now it's to the point where there's almost no power steering, and almost impossible to steer.
I replaced the pump last night and followed the burbing instructions in VADIS, turning lock to lock 20 times, lowering, turning more, etc.
I'm not sure where in the next few days it'll work itself out or not, but what're the chances it's the rack?
The car is still in great shape and the pump was cheap, but a rack is another story... Just looking for some input on possible causes.
thanks
Jim
Old Jul 15, 2009 | 07:46 PM
Is the fluid bottle good?
Old Jul 15, 2009 | 08:21 PM
borrone821's Avatar
Default yep
yeah, bottle's good, but how would that affect the steering that much.. no leaks or anything
Old Jul 15, 2009 | 08:30 PM
If the tube inside fell off it would airate the system and act like it is low on power steering fluid.
Old Dec 9, 2009 | 02:04 PM
parksjm's Avatar
Default RE: Power steering issue
Did you check the u-joint on the steering post?
In engine compartment, look down towards bottom of firewall oh LH side.
Try putting some lightweight oil on u-joint.
JP
Old Dec 9, 2009 | 02:05 PM
parksjm's Avatar
In engine compartment, look down towards bottom of firewall on LH side.
JP
Old Dec 9, 2009 | 06:31 PM
Bender's Avatar
the reservoir is the weak point as tech said but your rack is probably nearing the end of its life.
CarbonVirus
1998-2000 model year V70
May 9, 2012 07:15 PM
elmo_allen
Nov 1, 2010 07:10 PM
NasS80Tbo
Sep 23, 2008 12:56 PM
dalechner
Dec 6, 2007 06:16 PM
