Power Window Question?
Old May 1, 2007 | 04:29 PM
NCS60's Avatar
Default Power Window Question?
My driver's side window makes a high pitched squeal/scratch noise when it moves up or down and I was wondering how I could fix it. Do I need to adjust the window, clean the window motor, adjust the seal etc... Just looking for a little guidance for an easy (probably classified as a "stupid") question.
I tried several searches but I couldn't find the exact info on this (I searched power windows in general)
Any help would be great! Thank you.....
Old Jul 3, 2009 | 11:17 AM
jmeara's Avatar
Default Window Squeal
While at the dealer for some routine maintenance, I asked about that same trouble with my S80. The service rep said it is just that the tracks need lubed. the catch is that it's $100 just to pull the door panel off. I am going to tackle it myself today.
Old Jul 3, 2009 | 11:41 AM
Yes some grease needs to be put between the sliders and the tracks.
Old Jul 3, 2009 | 12:20 PM
volvoman69's Avatar
i would recommend **** lube to grease up the window, no joke
Old Jul 3, 2009 | 04:46 PM
jmeara's Avatar
Got both front windows done in about 30 minutes. Thanks to a search on this forum for "door panels" it was easy. It's here: https://volvoforums.com/forum/showpo...9&postcount=33 . I used a more conventional grease though. I recommend only disconnecting the tweeter since the window buttons are needed to position the blue sliders by opening and closing the window. I only had to pull the black foam insulation about one third of the way from the lower rear corner to get enough access for my grease applicator. Maybe that **** lube can fit into tighter openings. I am not familiar so I can't help there.
bucktooth78
Sep 22, 2018 05:41 AM
steved
Dec 20, 2008 05:37 PM
850GLTWAGON
Nov 21, 2008 04:14 PM
fjkai
May 11, 2007 03:22 PM
my3sons
Jan 21, 2007 09:44 PM
