Power Window Question
Old Jan 19, 2007 | 04:44 PM
my3sons's Avatar
Default Power Window Question
I have a 1998 S70. For the past month, the drivers side window has been acting sluggish as if the motor was about to go out. Yesterday, in the midst of a snow/rain storm, the drivers side window got stuck about 1/3 down. PLUS, all other windows would not move. Luckily, all other windows were up. I finally got the drivers side window back up by slamming the door while keeping my finger on the switch. Now, once again, no window will move, regardless of whether I try the drivers switch of the individual door switch.
Question - am I looking at a main switch problem OR a window regulator problem?
Any help is GREATLY appreciated.
Old Jan 19, 2007 | 08:59 PM
Default RE: Power Window Question
Could be a window switch problem.
Could also be a broken window guide.
You might have more than one problem there.
Old Jan 21, 2007 | 01:07 AM
steveroe's Avatar
Sounds similar to my window problems last year. Click on my name and read the string of posts. Like tech said, could be several problems.
My thoughts: It's not a regulator if all windows quit working. The main power goes to the left door switch from the wiring harness, then it is routed back to each window through the master door switch and the same harness. Good Luck, and you may want to find a wiring diagram. Try this site: http://www.volvotechinfo.com/WD123/
Old Jan 21, 2007 | 09:44 PM
my3sons's Avatar
Thanks for the help. I believe it is probably both the regulator and the switch. I am taking it to a mechanic tomorrow to let someone smarter than I handle it.
bucktooth78
Sep 22, 2018 05:41 AM
NCS60
Jul 3, 2009 04:46 PM
steved
Dec 20, 2008 05:37 PM
850GLTWAGON
Nov 21, 2008 04:14 PM
fjkai
May 11, 2007 03:22 PM
