Replacement headlight wipers
2004 S60R
I purchased a set of replacement wiper blades for the headlights, Scan Tech part # 274433. The blade adapter/mounting clip is different and doesn't fit. I tried to re-use my adapter but the new blade pivot pin is located slighty in-ward and doesn't fit my adapter. I already know "R" is a code for "nothing fits your model, dumbass" but even the headlight wipers??!!!
Anyone else ever used Scan Tech brand? Ideas? Dealer for correct blades?
I looked around a bit and it would seem that the wipers are common for all models. I checked IPDusa and PartsGeek.
http://www.ipdusa.com/version.asp?st...507&V_ID=12020
http://www.partsgeek.com/catalog/200...blade_set.html
I ordered a set of wipers from IPD a year or so ago, but a plastic piece on the wiper arm broke during installation, so I removed the arms and installed covers, which make an attractive alternative (albeit pricey).
http://www.vivaperformance.com/catal...roducts_id=562
Have you tried removing the actual blade from the new wipers and just replacing that piece? Never tried it, but I guess you could bend the little clamps (provided they are ductile enough) on the end and slide it out.
