S 60 Heater blower does not work?
I have a 01 S 60 and blower motor doesn't work at all?
At the blower connection the red wire has no power, The black has a good ground. I would think there should be 12V at the red thick wire? Does the ccm send the power to the red wire?
All fuses good!
Everything works on the CCM but the fan, the fan lights light up when you try to turn fan up. There are no codes coming up.
I just bought the car, and when I picked it up battery was low from sitting, and almost didn't start, now the fan doesn't work and air bag light on? The person I got it from said it did work for them. But IDK if that's true???
All fuses good!
There are two red wires. Which red wire does not have power? The one for the 4 pin or the one from the 2 pin?
Situation where my Snap On CTN10001 comes in handy. Problem is it died. Now to find the dealer when I'm not in the area he sells. A decent light probe works well too. Clip to ground and touch both metal tips on the fuse. ATC fuses have little metal nibs that come through for just this purpose. An ATC fuse can LOOK good, but in reality be broken. Looking up wiring diagram for you.
#18
Here's a link to Pg 125 (Group 87 - Climate Control System).
https://www.dropbox.com/s/o1sw3e640g...pg125.pdf?dl=0
Should be able to see it without a DropBox account. WTH 30+ goes to is beyond me, assuming a bus somewhere. Trying to figure out these diagrams. Been reading schematics for years (used to be my job). Their system of nomenclature and identification is funky. 11C/3 for the fuse? WTH? Volvo is fuse happy. Never seen so many fuse boxes in a car. Under hood, under dash (CEM), inside driver door, in trunk... egads.
#20
Go here:
http://www.matthewsvolvosite.com/dow...ng_diagram.pdf
They have it all online. Beats cropping pages out of my .pdfs. PITA. Page 25. Fuse 6 (11E/6) is a 50amp that powers fuses 1, 2, 3, 4 & 5 inside the door. Junction 53/415 could have a broken wire there or on 54/40C. BUT, if 53/415 is broken, then the functions of fuses 1, 2 & 3 (aka 11C/1, 2 or 3) wouldn't work. If it's 54/40C then all 5 functions on the first 5 fuses wouldn't function.
Do both power seats function? Yes? Then it's somewhere between the fuse #3 inside door and motor (solid wire, no junctions). If no, but mirrors and door locks work then it's at junction 53/415. If seats and mirrors/door locks don't work, then it's junction 54/40C or the big bus fuse #6 in trunk by battery. There, figured out the schematic.
Last edited by MarcM; 11-26-2015 at 09:09 PM. Reason: Added junction & connector point diagrams
