S60 2.5T AWD Cooling Fan Runs on High
Old Apr 24, 2016 | 09:10 PM
tycoon's Avatar
Default S60 2.5T AWD Cooling Fan Runs on High
2004 2.5T AWD Cooling Fan Runs on High
When the engine is running, the radiator cooling fan runs full-bore. The temperature sensor seems to be fine as the temp gauge reads accurately. I can run the car with the fan unplugged as long as I'm not in the city, so I assume the thermostat is opening properly, not that it affects the fan.
This problem started a few weeks after I replaced the radiator. In the process of doing so, I damaged an o-ring in the A/C system and much of the refrigerant leaked out before I could seal it. I have yet to drain the system and replace the o-ring. I suspect the low refrigerant might cause the pressure to drop, so it shouldn't make the fan kick on, but I might be mistaken.
I checked the voltage on the fan module control wire (purple wire into fan motor) and it reads 0.7 volts to ground when the engine is running. I believe this is the proper reading when the computer wants the fan to run high, so the problem is not the fan module integrated into the fan motor assembly.
Thank you for your help
Old May 5, 2016 | 02:19 PM
tycoon's Avatar
It was as I suspected. I replaced the o-ring and had the A/C system evacuated, then charged by a shop. Presto! Cooling fan is operating as it should! I hope this lesson saves somebody some frustration.
cwise
Nov 4, 2025 12:25 PM
bcolins
2001-2013 model year V70
Oct 24, 2013 09:13 AM
troys1992v240
Aug 11, 2012 11:35 AM
jdsmith
Dec 15, 2008 05:00 PM
