2003 V70 electric cooling fan runs continuously and kills battery
Old Oct 7, 2013 | 01:49 PM
bcolins's Avatar
Default 2003 V70 electric cooling fan runs continuously and kills battery
Anyone experienced this and/or have suggestions on how to troubleshoot it?<br />
<br />
After driving the car a few days ago, I noticed the cooling fan running after I exited the car,.....and again about a half hour (or more) later,...meant to grab the key and have a look, but got distracted and forgot to go back to it. Next morning the near new battery was completely flat.<br />
<br />
I took the battery out and gave it a full restore/recharge and today put it back in the car,...............large arc as I connected the battery cables and the cooling fan came on immediately confirming that this was most likely the cause of the dead battery.<br />
<br />
Suggestions?<br />
<br />
Brian in Austin
Old Oct 11, 2013 | 10:28 AM
webbch's Avatar
Engine coolant temperature sensor. Engine computer still thinks it's really hot and is trying to cool it down. I'd expect the car to run poorly when cold in such a situation however.
Old Oct 21, 2013 | 03:05 AM
bcolins's Avatar
Default Update
Replaced the cooling fan assembly yesterday; about a 30 minute job. Problem is fixed.
Old Oct 22, 2013 | 06:40 PM
webbch's Avatar
So was there a relay that had the contacts shorted? Just wondering how the motor got power to run continuously.
Old Oct 24, 2013 | 06:53 AM
bcolins's Avatar
There is an integral switching module on the fan. Apparently a circuit does the switching, and it fuses in the closed circuit mode. Gotta buy the entire fan to fix it.
$115 and 30 minutes to fix.
Old Oct 24, 2013 | 08:37 AM
webbch's Avatar
Thanks for the update. Good grief. Sometimes it seems like Volvo just has to be different from everybody else...in unnecessary ways.
Old Oct 24, 2013 | 09:13 AM
ES6T's Avatar
The reason there is a fan control module is to allow the fan to be controlled from 0-100% with a pulse width modulated signal. Other cars use relays, such as a high speed and low speed. This only allows two different speeds as opposed to a pulse width modulated signal which can control it at any speed.
troys1992v240
Aug 11, 2012 11:35 AM
Gmanpumps
Jan 13, 2011 05:34 PM
la verite 4l
Jun 14, 2008 09:54 AM
goldbrick
Sep 6, 2007 01:45 PM
