S60 Engine Fan Runs at High Speed
Old Dec 13, 2008 | 08:19 AM
jdsmith's Avatar
Default S60 Engine Fan Runs at High Speed
I own a 2006 S60 2.5T. The engine fan has started to run fast and loud all the time. I was told that there is a speed sensor that controls the fan speed based on temperature readings. Does anyone know anything about this? If it is a sensor, can the sensor be replaced without buying a whole new fan assembly? What else should I be looking for?
Old Dec 13, 2008 | 08:45 AM
Default RE: S60 Engine Fan Runs at High Speed
Usually if the coolant temp sensor is bad it will set the check engine light.
Old Dec 13, 2008 | 01:51 PM
jdsmith's Avatar
I had the coolant temp sensor replaced (check engine light was on and engine went to "limp" mode). The fan now runs fast and loud (check engine light is not on). I was told there is a separate speed sensor for the fan.
Old Dec 13, 2008 | 09:26 PM
It runs off of the ECT or from the A/C system thats all.
Old Dec 14, 2008 | 03:13 PM
jdsmith's Avatar
So, what do I need to do to fix this? My repair shop wants to replace the whole fan assembly.
Old Dec 14, 2008 | 08:12 PM
Did they check codes for all the systems?
Old Dec 15, 2008 | 09:03 AM
jdsmith's Avatar
No codes are currently showing up. I had a check engine problem that indicated air mass meter. They replaced it. Then they discovered a leak in the the air hose from the air mass meter/air filterareato the engine at the "boot". They replaced that. One code said I needed a new A/C sensor. They replaced that. Now the fan runs fast all the time. My A/C condensor does leak and I was planning on replacing it in the Spring. So, what are your thoughts?
Old Dec 15, 2008 | 09:50 AM
Maybe they put the wrong A/C sensor in the car. That can make the fan run like that.
Old Dec 15, 2008 | 04:54 PM
jdsmith's Avatar
Anything else I should have them check while I'm at it?
Old Dec 15, 2008 | 05:00 PM
Is he a Volvo specialist?
He really needs to read codes out of all the systems including the A/C system.
He would also be able to read all the sensors if he has all the proper equipment.
itr
Nov 22, 2010 07:05 PM
nextproject
Jun 20, 2009 06:41 PM
Long
Aug 25, 2006 11:38 AM
parrym
Nov 7, 2004 11:30 AM
