S60 low beam out
Old Oct 23, 2011 | 02:58 PM
dlaber's Avatar
Default S60 low beam out
My 2004 S60 passenger side low beam is out and its not the bulb and the fuse under the hood is getting no power- so Im assuming it may be the relay under the driver dash the in the cem. There are three and they are all the same --9442190A is what is marked. Is this a relay, a shunt or resistor? and is a 94442190A the same as a 9442190 resistor I see on some Volvo parts sites for the S60. They look OK but I'm hoping that's the problem- any thoughts?
Old Oct 23, 2011 | 08:41 PM
Nichals's Avatar
check for voltage at your light switch
open the drivers door
pop off the fuse panel and pushing from behind the whole switch assembly just pops out
2 clips at the top and one at the bottom (its the slightly tricky clip)
since your still getting your drivers side light the switch is unlikly but i thought ide metion it
other than that inspect as much of the wire harness as possible
Old Oct 26, 2011 | 05:25 PM
volvotech06's Avatar
I believe the relay is internal to the CEM/central electronic module. You may need a new CEM, I've seen it before
Old Oct 27, 2011 | 06:33 AM
dlaber's Avatar
Default Fixed
It was the bulb connection, it the plastic was brittle and the metal connections came loose.
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
Porkchop99
Jan 30, 2011 06:05 PM
corby1228
Nov 7, 2010 02:12 AM
MikeB28
Aug 19, 2010 05:20 AM
volvo40_2k
Jul 28, 2009 09:18 PM
