S60 Rear Brakes not working
I have an 06 S60 FWD and I recently discovered that my rear brakes were not working at all. I loosened the bleeder valve on the caliper but no fluid came out. I decided to disconnect the brake line to my caliper and I was surprised to see no fluid came out of the hose even when I pumped the brakes. It is the same situation for both rear brakes. I made sure to check the brake lines that run from the master cylinder to the rear brakes for any kinks or damage but they looked fine. I was thinking I may have a gunked up combination valve but I can't research anything about combination valves in my Volvo. Someone please help me so I don't have to drive with half my brakes working.
on mine was the component where the lines tap into - the ABS controller (electronics/solenoid) attaches to it. It was as simple as replacing the part and bleeding the brakes. Side note, on some models you can drive with the ABS controller removed - you just don't have ABS, so you could test by disconnecting.
yep thats the control module on the left, the control unit in the middle and the pump on the right. I see 3 different part numbers for the control unit + pump from Volvo (one is for cars without tracs/dynamic stability etc, the others are for cars with tracs/dynamic/stability) so best to see if you can see a part number on your car before shopping. Note I saw Tasca sells this new for $1500!!! but used on ebay are closer to $75. I'd probably talk to the dealer to confirm if you keep your existing control module but replace the pump and control unit (ie part # 30793490) whether programming is required.
