S60 running very rough
Old Aug 1, 2010 | 08:00 AM
hersedo's Avatar
Default S60 running very rough
Car is currently running on 2 cylinders. MAF sensor, coils, injectors, fuel pressure all check out ok. Also, after looking at it over 2 hours it wasn't always the same 2 cylinders that were firing. No codes are being shown currently. Seems odd that it would not have a misfire code.
A test light was attached to each injector plug. Each was tested individually and only 2 were receiving a pulsating charge. The other 3 received nothing. Therefore I assume PCM was not energizing all the injectors. Sounds like a bad PCM but I wanted to see if anyone had any other ideas. Thanks.
Old Aug 1, 2010 | 10:36 AM
432SC's Avatar
Bad PCM or possibly connector. -Steve
Old Aug 13, 2010 | 10:24 PM
hersedo's Avatar
It was the throttle body. Apparently its a common problem. Volvo has extended the warranty on this part to 10 years and 200,000 miles so I took it to the dealer for the fix.
Old Aug 14, 2010 | 01:04 PM
KeithS60&V70T5's Avatar
What year and engine is your S60?
Old Aug 14, 2010 | 06:02 PM
hersedo's Avatar
2002 2.4 liter (not a turbo)
Old Aug 15, 2010 | 01:17 PM
Manu Noypi's Avatar
What year models are affected on that TB recall?
Old Aug 16, 2010 | 09:00 AM
hersedo's Avatar
I believe it pertains to 1999 thru 2002 on certain models. Also, from what I've seen it only applies to North America but you should should check that fact. I called Volvo to confirm that I qualified for the extended warranty before I took it to the dealer. The Volvo customer service folks were able to validate it quickly using my vehicles VIN#.
This website has some info on the subject.
http://www.vexedvolvo.org/
naelec
Mar 11, 2013 03:20 PM
keaunym
Nov 17, 2010 12:55 PM
Pyrate
Apr 5, 2010 01:25 PM
nicolaselias
Sep 18, 2009 08:51 PM
