S60R Brake Job
Hi all,
I'm new to the forum, but somewhat mechanically inclined, mostly on older cars.
Planning to replace the brakes on my S60R (41k miles), save a little cash.
I purchased some replacement pads from Kragen, does anyone have an opinion on whether these pads are ok? (They were $45)
http://www.partsamerica.com/ProductD...19&PTSet=A
Also, does anyone know the thickness spec for the rotors on the S60R? When I run my finger across the rotor, it doesn't feel very smooth, perhaps the rivets are already hitting? - Anyway, need to understand if I can turn the rotors or they just need to be replaced.
Thanks!
Fred
Thanks!
Fred
If you don't turn/replace the rotors then you'll burn through the new pads a lot quicker. But member s60R said you can't turn them, and I imagine replacing them isn't cheap, so sacrificing the $45 pads life expectancy might be the better choice.
S60R: I'm not doubting you about the rotors inability to be surfaced. But I'm just curious if you know why. I was a mechanic for 5 years and have never seen a rotor that couldn't be surfaced (unless it was too thin already of course).
ORIGINAL: flanimal
I don't know the exact measurments or where I read it so I asked the tech that works on my car,(at least on the R) the rotor is already at about the min thickness.
PaddyG
1998-2000 model year V70
02-17-2014 05:23 PM
