S60r turbo problem?
I just purchased a 2004 s60r with 80k. had an inspection and everything came back clean, but when i drive the car now it doesn't feel right. i could just not be used to the turbo yet but when boost builds it is very choppy, and jolts almost like the turbo is going on and off from 2500-3500 rpm. does anyone know more about this, and is it normal for the s60r to drive like this. i am planning on taking it to a volvo specialist asap but would like to have some idea of what to tell them or expect. Thanks!
Could be the throttle module, although I thought that issue was more or less resolved by the '04 models. Might also be a misfire, as Mad Matt stated. The ignition coils do go bad over time.
"The message center will intermittently show a message saying its time for a regular service"
If you mean the time for regular service message displays after starting the engine and goes of after two minutes, that is normal. As far as the condition of "feeling very choppy and jolts", that is not normal. If you have records check the PCV system for service.
