Some help..
I have a 2001 Volvo S60, and it has some problems. First this is probably a stupid question but how do I properly set my headlights? Like I bought some new ones and Ill turn and twist them and they don't seem to look right. And then also is there a way to get rid of the error message (SRS AIRBAG- SERVICE URGENT) without taking it to the dealer? And then last another error message shows up: BULB LIGHT ERROR - REPOSITION BULB)how do i find out which one to do??
1. Not sure how to help
2. Not really. I have heard that if the SRS system has no current fault it will eventually reset itself. Normal code readers and resets will not reset the SRS. The dealer may be your best bet.
3. Take a walk around the car when it is dark. You will spot a bulb that is out. In the tail lights there are two lights for each side, one on top of the other. These are the most common bulbs to fail. You can also try to tap on the one that is out and see if it comes back on. Word to the wise, change all four at the same time in the rear lights. If you change one most likely the other on the same side will fail.
Lansdowne
09-22-2014 01:02 AM
Sanel30
02-18-2010 09:16 PM
