Squeaking camshaft bearing?
Old Dec 7, 2010 | 11:20 PM
Musicjunkie2k's Avatar
Default Squeaking camshaft bearing?
Hi Everyone, I have a 2002 S60 114000. Timing belt was changed at 98000.When I drive the car till it warms up it runs fine. after that i get an intermittent noise from the camshaft. The noise seems to come from the camshaft pulley closest to the front of the car. I can open the timing belt cover and it sounds like a groaning noise then it goes away and comes back. It seems to radiate across the top and front of the motor. I changed the serpentine belt and tensioner. that didn't help. The noise happens when the AC is on and the car is in drive or reverse. What is it? Should I be worried? How can I fix it? Any help is appreciated.
Old Dec 8, 2010 | 11:29 AM
ed7's Avatar
ed7
Hopefully the idler and tensioner were changed when the timing belt was replaced.
Since you changed the acc belt tensioner, the noise is probably coming from the AC clutch pulley bearing.
Get a suitable length of hose and stick one end in your ear and stick the other end down amongst the spinning bits and listen for the odd sound. You'll home in on it shortly.
Ed
chipbatton
Nov 13, 2010 07:29 PM
JHudson
Jun 21, 2010 04:04 PM
Steamroll9
Feb 16, 2006 11:55 AM
900 Aero
Sep 13, 2005 09:39 PM
rp850
Jul 27, 2005 12:45 AM
