Squeaking in Reverse
Old 07-15-2009 | 12:57 PM
jmaslanka's Avatar
Default Squeaking in Reverse
My '02 has started squeaking loudly when I move in reverse. The intensity of the noise is not always the same, and, in fact, it's not even always there, but it usually is.
The squeak only happens in reverse and only happens while moving, not braking. I honestly have no idea what it would be. Any thoughts?
Thanks.
Old 07-16-2009 | 10:46 AM
adub96's Avatar
it's your tires going over painted lines.
Old 02-22-2016 | 08:43 AM
Courtematt's Avatar
Same issue with my 98 V70, it seemed to start after I cleaned the engine with engine brite. So I guess I cleaned off some lube that was doing it's job...did you ever figure out what it was? I also recently did a front brake job...
JCVolvoS80
04-22-2006 02:27 PM
ludeless
03-14-2006 11:27 PM
Steamroll9
02-16-2006 11:55 AM
900 Aero
09-13-2005 09:39 PM
rp850
07-27-2005 12:45 AM
Quick Reply: Squeaking in Reverse
