Stock turbo questions please help thanks!
Hey y'all I drive a 2007 Volvo s60 2.5T fwd not the t5 not the r just base s60 I guess... So anyway to the point I just started upgrading my car and this week or next whenever I get answers I'll be installing a bypass valve an a manual boost controller and a turbo gauge .... Here is where my novice experience comes in I'm not sure what is a SAFE psi for the STOCK turbo and stock internals please help I have read 15 however not sure and don't want to mess up my baby! Thanks everyone for hopefully helping me out. Oh I forgot to mention I will be adding a cat back ex and a cold air plus new turbo piping.
Well I mean 1-2 honestly isn't worth the money I spent on the mbc from what I read stock is 7 psi and I've been told and read any stock turbo and internals should safely handle 12 -15 Thanks for the advice and I bought the gauge today I will put it in before changing
first, turbo Volvos already have an internal bypass valve so adding another is redundant.
also peak psi on the R's is around 15psi with a stable pressure of 12
since they are in the most part identical engines you should be able to run 15 all day and push 20 with minor risk
but it's going to kill your car very quickly and the other problem is, one does not simply increase the pressure...Volvos really don't like that and they also don't like speed chips. your best bet in reality is to sell it and buy an R
The ONLY way to increase the S60 in any way is with an ECU TUNE. There is nothing else that does anything but maybe help with air flow and or temperature (intake, FMIC, 3"downpipe, Catback exhaust) Any of these things do ZERO to get more power out of the S60 with out a proper tune to take advantage of the added air flow temp drop.. There is no way to increase boost or add HP or Torque in these car with out the use of one of the below companys.. These P2 ME7 Volvos are set up different than older models.
Your choice are
Ardideas.com ARD tune
Volvo & Saab Performance Parts & Accessories: ViVA Performance Rica tune
Welcome To Elevate Cars | Elevate Cars Auto tech tune
Volvo Tuning - BSR Innovation 'PPC' BSR tune
