Stuttering Problem
Old May 31, 2022 | 05:45 PM
Vanni's Avatar
Default Stuttering Problem
I have an 03 s60 that when I cold start it, it stutters but it does not dies and stops stuttering when I pit it in gear. Then when I am coming to a stop the car stutters until I stop but it still doesn't die. I replaced the throttle body and checked for leaks and have found none.
The car also has these 2 codes: P2187 and P0507
Old May 31, 2022 | 09:50 PM
the P2187 is a lean mix at idle - which suggests an intake air leak somewhere - torn vacuum line, intake boot etc. These can be hard to find so after doing a visual inspection for the obvious, you can spray around with some carb cleaner to see if any gets sucked in and bumps the idle. After that, you'd probably need a smoke test done. Another thing to check is the PCV system as its tied into the intake.
Last thought - who did the work on replacing the throttle body and how long ago was that? These are drive by wire cars so I'm wondering if the calibration was done correctly.
Old Jun 1, 2022 | 01:03 PM
Vanni's Avatar
I replaced the throttle body since it was the Bosch one which is plug in according to FCP Euro and other forum members, I also replaced the gasket. I did the glove test to check the pcv system and it was good. I also did the smoke test which was also good. Finally i checked for vacuum leaks and did not find any leaks, the last thing I have to do is spray around with carb cleaner to see if it raises the rpms.
Old Jun 1, 2022 | 07:03 PM
did you also do the calibration for the TB?
https://www.swedespeed.com/threads/e...how-to.153009/
Old Jun 1, 2022 | 07:08 PM
Vanni's Avatar
Yeah I did
Celik
Penta
Mar 28, 2022 01:04 PM
mikhro
Apr 13, 2014 08:58 AM
triggerman
Jan 23, 2011 02:13 PM
New Volvo Driver
May 21, 2009 07:30 PM
conceptmuscle
Dec 28, 2007 01:40 PM
