timing belt replacement costs
I had my local dealer quoted me $900 parts and labor. Thats for belt, pully and tensior. The tensior and or pulley is where most failures come from not the belt in most cases. Make sure that you do the entire Kit. I also replaced the Water pump at the same time because it runs off the same belt and for the added $50 for the part it was worth the piece of mind that im not going to have to pay for this twice.
Your timing belt was due at 10 years (ie in 2018)... are you the original owner - or is it possible a prior owner had the belt replaced on schedule? If not you're about 3 years past due.
timwu12
Jul 3, 2012 06:05 PM
