turbo compatable??????????
Yes it will work, your car came with TD04HL-13T angled flange turbo, the 98 probably has the TD04HL-13G straight flanged turbo. You can simply swap the cold side and guts from the new turbo into your current angled exhaust housing. Very easy to do. Let me know if you need more help.
just remember to check and make sure the coolant ports are both on the back side of the CHRA and your good to go.
-NJGB
-NJGB
Engines and turbochargers
12T - B4204T 160hk 1998-1999, S/V/40 twin scroll
12T - B4204T5 165hk 2000-, S/V/40 twin scroll
12T - B5204T3 225hk ??-?? C70
12T - B5204T4 163hk ??-?? C70
12T _ B5204T5 180hk ??-?? S60
14T - B4194T 200hk 1998-1999 S/V/40
14T - B4204T3 200hk 2000- S/V/40 twin scroll
14T - B5254T2 200hk ??-?? S60/V70
13G - B5254T 193hk 1996-1998, straight outlet from turbine
13G - B5244T 193hk 1999-2000, angled outlet from turbine
13G - B5244T 200hk 2001, angled outlet from turbine
15G - B5234T 225hk/B5234T5 240hk 1994-1995, The old conic outlet
15G - B5234T 225hk/B5234T5 240hk 1996, straight outlet form turbine.
16T - B5234T4 250hp kom 1996 i 850R man, straight outlet from turbine
16T - B5234T3 240hp 1997-1998 finns i S/V/C70 T5, straight oulet from turbine.
16T - B5234T3 240hp 1999-2000 finns i S/V/C70 T5, angled outlet from turbine.
16T - B5234T3 250hp 2001- alla S60/V70N T5, angled outlet from turbine.
18T - B5234T4 250hp 1997-1998 only S/V70R man FWD/AWD, 275/60 wastegate and straight outletform turbine.
18T - B5234RT 250hp 1999 only V70R AWD, 4-vxl aut, 300/70 wastegate and angled outlet form turbine.
19T - B5244RT 265hp 2000 endast V70R AWD, 5-vxl aut, 300/70 wastegate and angled outlet form turbine.
Engine
Turbo type
Wastegate
ECU revision
Volvo part no.
4 cylinder
B4204T TD04L-12T ---/-- EMS2000 --------
B4204T5 TD04L-12T ---/-- EMS2000 9447272
B4194T TD04L-14T ---/-- EMS2000 --------
B4204T3 TD04L-14T ---/-- EMS2000 --------
5 cylinder
B5254T2 TD04L-14T Bosch ME7x 8692518
B5244T3 TD04HL-13G ---/-- Bosch ME7x --------
B5234FT TD04HL-15G 150/40 Bosch M4.3 5003910 (Exch)
B5234FT TD04HL-15G 150/40 Bosch M4.3 8601070 (Exch)
B5234FT TD04HL-15G 150/40 Bosch M4.4 8601238 (Exch)
B5234T3 TD04HL-16T 218/60 Bosch ME7x 9471655
B5234T3 TD04HL-16T 275/60 Bosch ME7x 8601691 (Exch)
B5234T3 TD04HL-16T 275/60 Bosch M4.3 (??) 8601691 (Exch)
B5234T4 TD04HL-16T 216/60 Bosch M4.3 1275663
B5234T4 TD04HL-16T 216/60 Bosch M4.3 8601239 (Exch)
B5234T4 TD04HL-16T 216/60 Bosch M4.3 8601226 (Exch)
B5234T4 TD04HL-18T 275/60 Bosch M4.4 9185628
B5234T4 TD04HL-18T 275/60 Bosch M4.4 8601456 (Exch)
B5234T5 TD04HL-15G 150/40 Bosch M4.3 9146785
B5234T8 TD04HL-18T 300/70 Bosch ME7x 9454563
B5234T8 TD04HL-18T 300/70 Bosch ME7x 8601461 (Exch)
B5244RT TD04HL-19T 300/70 Bosch ME7x 9471657
B5244RT TD04HL-19T 300/70 Bosch ME7x 8601693 (Exch)
B5254T TD04HL-13G 150/30 Bosch M4.4 8601227 (Exch)
B5254T4 KKK-K24 --- Bosch ME7x 8602805
Engine
Turbo type
Wastegate
ECU revision
Volvo part no.
4 cylinder
5 cylinder
